raising my hummer
Old Jan 5, 2010 | 10:27 AM
fishin301's Avatar
Default raising my hummer
i want to put 305/70/16 on my truck,how high do i need to raise it to get them to fit or do i need to just level the front end with the torsion bolts.is the rear of truck going to be an issue, does it have to be raised also,or is there enough clearance already.thanks in advance
john
Old Jan 5, 2010 | 11:29 AM
largemouthbass's Avatar
you do not have to do anything for them to fit. You can fit up to 315 tire on stock setup.
Old Jan 6, 2010 | 02:46 AM
fishin301's Avatar
thanks largemouthbass
Old Jan 6, 2010 | 02:49 AM
fishin301's Avatar
Default lifting truck
if i dont raise the front end and put 305/70/16 will there be any rubbing
Old Jan 6, 2010 | 06:38 PM
You should be fine although I have heard this can vary from truck to truck. Some people have noted very slight rubbing with stock 285's. I had no rubbing with the 285's and I had no rubbing when I put on the 315's. I only now have slight rubbing at full steering lock since I leveled the front.
The leveling changes the angles of front end components and causes slight rubbing on the sway bar. This is nothing to worry about.
I say go for it! You will be stoked with the wider tire for sure and will most likely have zero rubbing issues.
When/if you do decide to level your truck make sure you do a search and read all about it before moving forward. It is a fairly easy thing to do but there are certain things you should know.
Old Jan 25, 2010 | 04:51 AM
Insecedic's Avatar
I have also thought about raising my internat prices but leaving my shop prices as they are. I am fairly certain my local market could not handle the icrease.I could use my shop as an off retail type of market.
never2big
Feb 1, 2012 07:46 PM
NJHummer18
May 13, 2009 11:59 AM
KS Trekker
May 23, 2008 08:05 AM
Greenblade
Oct 5, 2006 02:08 AM
