rains and pours
Old Mar 11, 2015 | 06:59 PM
happythree's Avatar
Default rains and pours
looking for the leak, i started up an heard a little clicking,squealing. it got louder, seemed like the tension pulley. it got softer.
i replaced the pulley the next day even tho it was quiet.
the old one felt as good as the new one so i saved it, in the box!
now hearing some squeal, slight. belt?? not steady but repetitive.
i was also low on steering fluid but no change when added.
anyone using belt dressing spray?
i never hear of it used on serpentine belts??
should i try it?
Old Mar 11, 2015 | 07:32 PM
Bunger's Avatar
I wouldn't use belt dressing. I think it attracts dirt and starts grinding away at things.
One other thing to check is the Idler pulley on the right side of the motor. Those usually start going about the same time as the Tension pulley goes.
Old Mar 11, 2015 | 09:44 PM
happythree's Avatar
Default oops! did that!
i replaced the tension pulley the next day even tho it was quiet.
so im still lookin,,,listening
oops i forgot the idler!!! oh my brain!!
Old Mar 12, 2015 | 06:06 AM
Is your belt sticky? If so that's where your coolent leak is too.
Old Mar 12, 2015 | 10:13 AM
happythree's Avatar
thanks guys, this morn its quiet and coolant looks same as wed???
still have slight oil on pan, front, bottom only, not running down from above. leaky pan?, crack? in aluminum?
autobots
Feb 21, 2017 03:09 PM
theBroken
Sep 23, 2009 08:37 AM
bonzaiii
22
Dec 8, 2007 08:54 AM
