radiator coolant
Old Oct 2, 2011 | 12:05 PM
ChrisB's Avatar
Default radiator coolant
Hi, In the manual it says to use dex-cool fluid.
Is this really necessary, or can another 50/50 be used to top up the fluid in the expansion bottle.
Old Oct 3, 2011 | 01:02 PM
I personally would spend a few bucks for the DEX-COOL 50/50. Not sure when the last time your coolant was changed. For your 06 with DEX-COOL you should be flushing and changing your coolant in 2011 anyway. 5 years or 150,000 mi.
If you do want to change over to standard glycol based anti-freeze then your entire system should be flushed twice and then filled with the glycol based anti-freeze. Change glycol based every 3 years or 40,000 miles. See you are not saving anything by changing to glycol based anti-freeze. Add up the flushes, and shorter intervals of change and you are actually spending more $.
Directly from DEX-COOL:
CONTAMINATION:
Mixing conventional green coolant with DEX-COOLŽ will degrade the service interval from
5yrs./150,000 miles to 2yrs./30,000 miles (50,000 km) if left in the contaminated condition. If contamination occurs, the cooling system must be flushed twice immediately and re-filled with a 50/50 mixture of DEX-COOLŽ and clean water in order to preserve the enhanced properties and extended service interval of DEX-COOLŽ.
Old Oct 4, 2011 | 04:45 PM
ChrisB's Avatar
Thanks fot the info. Where do you get Dex-cool stuff.
Old Oct 4, 2011 | 09:19 PM
Pretty much any auto parts store shoudl have it!
Old Oct 5, 2011 | 07:41 AM
WannaScoopaDis's Avatar
Personally, I am not a big fan of the Dex-Cool. I just never really liked it. When i bought my hummer, I had to get the radiator replaced due to the common leaking problem the 06 had, so I had the shop flush my system and switch me to anit-freeze. It seems that she runs a few degrees cooler with the "green stuff". But I am sure the Dex-Cool stuff works just fine, it does last longer, and GM wouldnt have used it if it didnt work. Just my $.02
Humm3r
Oct 16, 2012 07:24 PM
Herm
Jan 24, 2008 07:04 AM
syphon
Jan 2, 2008 01:26 PM
sgt940
May 23, 2007 08:46 AM
GregDiesel
Jan 6, 2006 03:24 PM
