Question about changing gear ratio and ABS
Old Jul 19, 2010 | 01:19 PM
ador's Avatar
Default Question about changing gear ratio and ABS
I was told that when you change your gear ratio (ring and pinion), that process disables your ABS brake.
And that you will need a smartchip programmer or other brand to re-activate your ABS.
Is this true?
Old Jul 22, 2010 | 03:54 PM
HumminNBoatin's Avatar
You were told wrong.
The abs speed sensors are in the hubs. All they do is detect differences in wheel speed to make the proper brake adjustments for ABS and traction control.
What size gears are you going to?
Old Jul 23, 2010 | 01:38 PM
ador's Avatar
Two different mechanics, from two different off-road shops told me about the need for a programmer. I was told that changing my ring/pinion to 4.88 will DISABLE my ABS.
I wil be getting that eventually since I want to re-calibrate my speedo to match my 38 tires.
I am changing the gear ratio to 4.88 since I now have 38 tires.
Old Jul 23, 2010 | 03:23 PM
Sadly they are mistaken.... you will want a programmer to recal your speedo.
ABS senses differences in wheel speed and that is it....
Think about it-your abs tone rings are in the hubs. You already changed your tire size essentially changing your final gear ratio.... did you need to do anything to your abs system then...?
Old Jul 23, 2010 | 08:38 PM
ador's Avatar
Thank you for the clarification HumminNBoatin. I will discuss this matter with my mechanic. I have don't have any knowledge when it comes to the H2 mechanical parts and it's function.
roycel
16
Apr 24, 2014 11:05 AM
drgstrSMB
45
Jul 16, 2012 05:50 PM
o004hp
Aug 13, 2010 10:36 PM
ador
Jun 29, 2010 12:39 AM
raye
Oct 11, 2008 10:05 PM
