question
Old Jan 15, 2007 | 02:35 AM
KTMCanuck's Avatar
Default question
Hi there,
Anyone had problems going from four wheel high lock to four wheel high? I've tried the 25 foot reverse while you turn mentioned in the manual (page 2-25) butthe front still seems locked. Anyone else had this or have a technique to get it to release?
Old Jan 15, 2007 | 02:49 AM
Fireman's Avatar
Default RE: question
You say it *seems* locked.Does the indicator showthat it is, .. or does it just feel like it when you're driving?
I have not had this problem. But, you may try putting the t-case in neutral by holding the 4 low and 4 hi lock buttons down. The try to go back to 4 hi. Be sure to set the parking brake too, cause if it goes into N, it will roll even in park.
Old Jan 15, 2007 | 09:35 AM
KTMCanuck's Avatar
Thanks Fireman,
The only the first indicator is on which I believe should be correct. It's just that when you are driving on dry pavement especially a tight turn, that you can feel the front end binding.
Old Jan 15, 2007 | 01:41 PM
importkiller's Avatar
I had to put it in reverse and make 10 mph donuts in reverse for it to break out of 4lock the first few times.
Old Jan 15, 2007 | 02:08 PM
KTMCanuck's Avatar
Thanks guys! Now to go and find a nice clear parking lot.
Old Jan 15, 2007 | 02:37 PM
Fireman's Avatar
I'd still try puttingthe t-case inN too. Just double check the manual, cause I don't remember which two buttons you hold down to go into N (been too long since I read it). Then the N should light up that you are in it. Check by putting the tranny in drive andtrying to drive forward.. if you don't move then you are in N (t-case). Return the tranny to P or N, and then press the 4 high button until it lights up, and more than likely you should be in 4H after that. And of course, don't forget the P brake.
If you also try to back up thing, like IK said, do a couple of turns while doing it.
Hope it works for you.
Old Jan 15, 2007 | 03:25 PM
KTMCanuck's Avatar
Hi Fireman,
I got it into neutral by placing the tranny (auto) in neutral, parking brake on and pressing 4hi and 4low-lock for 10 seconds. After being sure the t case was in neutral I then placed it back into 4hi. This hasn't unlocked the front so I'll try the backing-up technique.
Old Jan 16, 2007 | 01:59 AM
KTMCanuck's Avatar
ok now i'm dizzy! Did six complete donuts at walking pace in reverse and still locked. Time for the dealer again!
Old Jan 16, 2007 | 02:38 AM
Fireman's Avatar
Sorry to hear nothing worked. Like you said, it sounds like a visit to the dealer is needed.
Old Jan 16, 2007 | 02:58 PM
hummerfun's Avatar
Hi I'm new to this forum!
Just had this issue happened to me last week and I had to take it for service. They fixed within an hour, not sure exactly what they did. But I had the Serv 4wd light on.
