Put washer fluid in the Coolant tank/ resrvoir
Old Jan 11, 2010 | 01:05 PM
2L8IWON's Avatar
Default Put washer fluid in the Coolant tank/ resrvoir
OK, let's get the I'm a dumbass and yes I actually did that jokes out of the way. On the way to work this morning my wiper fluid stopped working so I stopped to put some in. Thinking that I knew what I was doing, in the dark, I went to add washer fluid and accidentally put it in the coolant reservoir.
My question is this; is this a big issue? Should I flush the radiator? Coolant reservoir, etc? I drove the truck for about 25 minutes post contamination. There is a big "dex-cool" logo on the cap, am I doubly screwed?
Any help you cold provide would be awesome since I am stationed in England and a dealership is a long way away.
Jesse
Old Jan 11, 2010 | 07:12 PM
BrickWurX Mfg.'s Avatar
I think the wiper tank hold nearly a gallon of fluid. Thats a lot if it reacts poorly. With wiper fluid being mostly water, an anti freezing agent, or alcohol, it could effect the coolant based on the chemical content of either. I would have drained and flushed the radiator fluid before driving just in case. It may be important to find out whats actually IN the wiper fluid to make sure it doesn't react with your coolant.
Someone else may chime in with a bit more knowledge.
Good luck.
Old Jan 11, 2010 | 08:02 PM
drtom's Avatar
Banned
Default in no expert
id drain a gallon and add a gallon of the right stuff
washer is probably water and alcohol and the al will evaporate
btw i saw a jug of washer fluid in my barn, picked it up, frozen!! great stuff huh
tom
calif phil
Jan 13, 2015 07:38 PM
Caraddict
Jun 6, 2011 06:53 AM
armarto
Jan 20, 2010 12:31 PM
loud pipes
Jan 20, 2010 04:37 AM
theBroken
Dec 17, 2009 08:17 AM
