Heated washer fluid
Old Oct 28, 2013 | 08:19 AM
calif phil's Avatar
Default Heated washer fluid
I had the GM recall on my H2 to remove the defective windshield washer heater. I found this company that makes a better replacement system. I think I will add this on my to do list someday. Welcome to AlphaTherm the world leader in the development of Heated Wash
Old Nov 3, 2013 | 07:22 PM
calif phil's Avatar
I received my new washer heater yesterday. It took about 10 min to install. Works great and I am glad to have it back to working like it came from the factory.
Old Nov 3, 2013 | 11:14 PM
LoJac963's Avatar
You bought from the link above? I'm interested in this also as the bugs here in AZ are ridiculous especially on the freeways.
Old Nov 5, 2013 | 09:09 AM
calif phil's Avatar
Yes I did I actually became a dealer for them.
Old Nov 5, 2013 | 03:12 PM
LoJac963's Avatar
I checked out their site but what all does the install entail? I don't have the hot shot button or whatever it was called so it would have to be installed as factory. I'm assuming it replaced the stock pump?
Old Nov 6, 2013 | 08:39 AM
calif phil's Avatar
My H2 came with the heated washer fluid so it was a real easy 10 min. install. If yours did not come with it then you will need to add wiring and a button. Give them a call and they can tell you what you need, very nice folks and they don't mind taking the time to talk with you.
Old Nov 6, 2013 | 04:20 PM
LoJac963's Avatar
ah so you keep the stock plain washer fluid on the steering column and add a button to use the heated only when you need it?
Old Nov 7, 2013 | 08:15 AM
calif phil's Avatar
That is correct. My H2 is a Limited Edition and it came with a button for the heated washer fluid. GM had a recall and gave owners a $100 check to have it removed instead of repaired. I had that recall done last year and now found a source for a replacement heated washer and I was impressed with the quality and low price.
Old Nov 7, 2013 | 09:16 AM
fyr145's Avatar
Calif phil,
So let me see if I have this correct.........
If you DO have the limiter edition H2 model, then you can use the AlphaTherm AT-37 unit.
But if you do NOT have a limited edition H2 model, the you could use the AlphaTherm AT-38 OD unit.
Would this be accurate to say????
Old Nov 7, 2013 | 12:55 PM
calif phil's Avatar
Yes you have it correct. Did you watch the install video on the link? It shows how easy it is to install it. I think it's a great product and priced right.
