problems after PCM flash
Old Apr 25, 2010 | 08:15 PM
fullbore55's Avatar
Default problems after PCM flash
I recently had my PCM recalibrated by PCMforless. I am happy with everything but I discovered an error message(SERV TPM). It came on twice after turning off the cruise control when getting off the interstate. After stopping, it went out. I also noticed my climate control will only blow cold air, or hot air, with no adjustment through the temperature mixing ****. I have hot air on all settings except the coldest. I guess it could be a coincidence but I would check to see if anyone else had this issue before taking the H3 to the dealer.
Old Apr 25, 2010 | 11:44 PM
Sugarphreak's Avatar
SERV TPM: Tire pressure? Are you running 35+ psi in your tires... if not, this error with a light will pop up on your dash.
Not sure about the second thing, that sounds odd... maybe give PCM4Less a call and ask before you take it to the dealer?
Old Apr 26, 2010 | 08:15 AM
RKSmith163's Avatar
Likely unrelated to you PCM flash. Reseat your PCM connections to see if that helps.
byeatts
Nov 3, 2013 11:00 AM
maktinator
Sep 15, 2013 10:14 AM
branstone
18
Mar 27, 2008 08:51 PM
TigerLily
Jan 17, 2007 01:34 PM
HummerGuy123
Jul 28, 2006 02:27 PM
