Problem with Rockford fosgate audio kit
Old Apr 12, 2014 | 05:11 PM
accely's Avatar
Default Problem with Rockford fosgate audio kit
just installed the rockford fosgate kit and it's not getting any power it seems. The setup was very easy.... plug in the amp/sub cable, ground it, tap the power cable to the fusebox power on driver side, and connect the new harness to my navigation unit. Everything was simple... but it's not powering up I guess.
Any thoughts/ideas why? I assume this kit shouldnt have a problem with an aftermarket navigation (clarion nx501) since all the wiring harnesses match up but maybe not..?
I also put the door speakers in and they are working fine
Old Apr 15, 2014 | 03:09 PM
H2CANEPADESIGN's Avatar
I dunno, I just installed the same kit last week. found it on somo for $299. Mine works fine, its loud as hell. My only complaint is that there is no way to shut the sub off other than unplugging it.
Make sure you have power to the sub via that orange wire that you had to tap into in the side fuse panel and a good ground.
Old Apr 15, 2014 | 04:43 PM
accely's Avatar
nice.. that's where I got my as well.
What kind of deck do you have? someone mentioned they thought it doesnt work with 3rd party navi, only stock deck.
did you also tap the power off the fuse wire like the instructions said? and use the ground in the B pillar?
Could you take a picture of your orange wire tapped? maybe I misunderstood it from the diagram
Old Apr 15, 2014 | 07:37 PM
can u pm me your phone #? ill send over a pic via text. yes I tapped the orange wire in the side fuse panel per the instructions and used the ground in the b-pillar. and yes, I have a stock deck.
Old Apr 16, 2014 | 09:39 AM
accely's Avatar
pm sent.
Anyone else have this audio kit working with 3rd party nav?
Old Apr 19, 2014 | 02:48 PM
accely's Avatar
So let's assume this kit doesnt work with 3rd party navs
Here's my idea to get the subwoofer(and amp?) working:
FROM the sub/amp box you have the following cables:
power (red) - plugged into the fuse box
ground (blk) - connected to B pillar stock grounding
The 4 other cables that run to the new wiring harness are:
grey/greyblack
white/whiteblack
Now I also have this available options on my nav via banana plugs, same colors...(grey/greyblack and white/whiteblack)
Could I cut the 4 wires, aka bypassing the wiring hardness and run them directly into my nav unit? Thus getting the subwoofer to work ? would the amp then work too? I mean technically all cables are connected then.
does this make sense at all?? or is there something in that new T wiring harness that is playing more of a role than just making the electrical connection to the would be stock nav ?
I figure it's either this option, or I'm gonna resell the kit minus the door speakers and for the little money I'd get after shipping I probably wont go the selling route.
Old Apr 22, 2014 | 03:00 PM
just need a signal,power and a good ground. so I think your on the right track.
My stock headunit just took a dump!
grey714
Aug 26, 2010 11:57 AM
EarlsSVT
Jun 9, 2010 09:22 PM
h2sutithaca
Feb 3, 2010 10:29 AM
PhxH2
Sep 24, 2009 05:02 PM
JeepeaterH3
Mar 16, 2008 02:44 AM
