Power outlets to switched 12v?
Old Jun 13, 2010 | 09:40 PM
jbs45's Avatar
Question Power outlets to switched 12v?
The front two power outlets under the radio, what's the easiest way to make these turn off when the engine is off?
Old Jun 15, 2010 | 11:51 AM
jbs45's Avatar
No one has done this?
Old Jun 15, 2010 | 06:26 PM
Broken Halo's Avatar
The best (and easiest) way to do this is get yourself a 30amp relay switch (Radio Shack). Cut the feed wire to your lighter plugs and use that as the 'input' voltage to the relay. From the output side of the relay, feed that back to your lighter plugs. Use the power wire feeding your radio as the 'trigger' wire to the relay. Run the relay ground wire to any bolt/screw under the dash that goes into metal. This way it will operated with the ignition off/on, and still be protected by the lighter plug fuse under the hood.
Old Jun 15, 2010 | 09:50 PM
drtom's Avatar
Banned
Default great simple solution
and relays are cheap and reliable.
i used to use old horn relays,,real cheap!.
or a the junkyard grab a handfull from a wreck, most cars have a bunch.
they use the flat faston conn, crimp on and be done
tom
jbs45
Jul 5, 2022 08:49 AM
nelly27281
Jun 16, 2015 04:29 AM
SedonaBoundH3
Apr 13, 2012 02:21 PM
David78
Jul 31, 2010 04:40 PM
Autumn Walker
Mar 26, 2010 02:17 PM
