pinkish drip
Old Mar 8, 2017 | 09:12 PM
DesertDog's Avatar
Default pinkish drip
So i'm in the middle of pulling the front diff out for rebuild and noticed a pink-ish drip from the wires on the right front side of the block near the A/C condenser. I thought it was power steering fluid but the pump is on the other side, also it didn't really have a strong smell.
Anyone have any ideas what and why this is happening?
Old Mar 9, 2017 | 10:08 AM
oceanbrave's Avatar
Coolant from somewhere?
Old Mar 9, 2017 | 11:38 PM
DesertDog's Avatar
I guess it could be, ill look around for some leaks.
Old Mar 11, 2017 | 11:20 AM
DesertDog's Avatar
Ok traced it an area under the water pump, i also noticed my fan clutch making noise.......time to change both i guess.
Old Mar 11, 2017 | 04:55 PM
calif phil's Avatar
Most of the time the water pump is good. It's just the gasket that leaks. I just replaced mine and since the pump was perfect I just replaced the gaskets with some good Fel Pro gaskets. No drips now. It's an easy job.
Old Mar 11, 2017 | 06:18 PM
madmayo's Avatar
That pink antifreeze is dexcool. I get it flushed out of every vehicle i own. It becomes very acidic if not changed regularily and will eat gaskets. Apparently the new stuff is better. If you flush it out. You have to getevery drop out.
LoJac963
Mar 17, 2014 08:22 PM
mgurgone
Feb 21, 2011 06:49 PM
dcasares
May 10, 2010 04:48 PM
