Picture Of Plastic Fork that breaks
Old Sep 13, 2010 | 03:35 AM
Widespread Hummer's Avatar
Man what you describe does not sound good. The loud "bang" you hear up front every once in a while when turning is most likely the chain slipping in your transfer case. When turning on dry pavemtn it puts a great deal of torque on the chain and eventually the chain stretches and begins to slip across the gear teeth. "Crow-hopping" or jumping when you're turning is correctable, loud bangs usually aren't. Not trying to be the bearer of bad news and I could be wrong, but it sounds very similar to a situation I had with a previous Grand Cherokee. Good Luck.
Old Sep 15, 2010 | 07:31 AM
greencarpet's Avatar
Default Changing the plastic fork yourself
Ok thanks,has anyone changed out this fork themself,what all has to be done and what other parts besides the fork or just the fork needs to be changed
Old Sep 17, 2010 | 10:09 AM
steve lenz's Avatar
2000 grand to repair fork isn't drivetrain warranty 5 yrs 100000miles even 2006s should still be covered! warranty automatically transfers even if you did not buy it new!
Old Sep 17, 2010 | 10:54 AM
Slash x's Avatar
Unhappy
If I am not mistaken, 5 year/ 100,000 mile warranty only applies to 2007 and up GM vehicles.
2006 is not covered under the extended drivetrain coverage
Old Sep 17, 2010 | 06:45 PM
Brian C D's Avatar
Hey all, When h3 owners have had a problem with the shift fork and the truck being stuck in 4 hi or 4lo, did the dash light indicator change as if the shift did occur,or did that stay stuck as well. Thanks
Old Sep 17, 2010 | 10:24 PM
4DIGR's Avatar
06's were 4 year 50,000 miles warranty.
Guy called CBphoto over on clubhummer of road did a write up on changing the fork.
Old Sep 17, 2010 | 11:40 PM
drtom's Avatar
Banned
Default lites ,no lites?
Hey all, When h3 owners have had a problem with the shift fork and the truck being stuck in 4 hi or 4lo, did the dash light indicator change as if the shift did occur,or did that stay stuck as well. Thanks the lites dont follow the action or lack of, they just lite when told there is "supposed to be" action,so it looks like youre ok,,when youre not
theres no feedback,closed loop type,to verify the action, you know when tires screach and jump.
very rough on tran clutches,gears,tc chains.
so i hear
Old Sep 18, 2010 | 12:38 PM
steve lenz's Avatar
wow, sorry guys.
Old Oct 8, 2010 | 01:03 PM
Jo Morton's Avatar
Default shift fork
I hit a pot hole that was huge and heard and felt breaking. The dealer says that it is the shift fork and that since it is a normal occurance of 2006 H3s then it is not covered under my insurance claim. (which hitting a pot hole is considered a collision and covered under insurance). Note: the car quit steering both in tight turns and reverse turns right after i hit it . I say the hole caused the break. They say it would have happened anyway at anytime. I say prove it!
Old Nov 14, 2010 | 11:32 AM
raycraftoncape's Avatar
Thumbs up Plastic Shift Fork
Thanks everyone for your posts you certainly pointed me in the right direction and saved me a lot of $$$$. Had my vehicle checked by a Hummer technician and to no surprise it was the plastic shift fork. I even talked to GM and they paid 50% of the repair under their good will program since it was out of warranty. Mileage when problem occurred 57,000 Miles.
Thanks again
