Performance Possibilities
Old Nov 22, 2007 | 02:32 AM
TheGunnyRet's Avatar
Default Performance Possibilities
2007 H3 3.7 ltr info:
For reference; WIX Part Number: 42013, Style: Air Filter, Service: Air,Media: Paper
Height: 8.875
Outer Diameter: 5.820
Inner Diameter Top: Closed
Inner Diameter Bottom: 3.590
Ends: Plastic
You can get custom Filters from AEM p/n 21-2049DK, S&B-R1142 w/powerstack, Racing Sports Akimoto Funnel Ram p/n 02356, True Flow p/n 10207, aFe p/n 24-90023.
Spark Plugs: Stock=Champion Double platinum7437 .043"
ACDelco SPARK PLUG 41-103 SPARK PLUG, IRIDIUM
Performance: Brisk Premium ROR15LGS spark plug, Pulstar™ Pulse Plug Model: EF-1, E3... E3.66.
Fitch Fuel Cayalyst P/N F3824.
SP Brake Rotors are for 2006, but I am sure they will fit 2007 also.
Rotors
Front-F57-03 Drilled and Slotted Rotors (Sold in Pairs) 315.1mm Vented 6 Lug
Rear-F57-04 Drilled and Slotted Rotors (Sold in Pairs) 311.9mm Solid 6 Lug Rotor
Front-T57-03 Slotted Rotors (Sold in Pairs) 315.1mm Vented 6 Lug
Rear-T57-04 Slotted Rotors (Sold in Pairs) 311.9mm Solid 6 Lug Rotor.
Engine Oil filter;
TRUFILTER 2006 HUMMER H3 3.5L L5 F/I TFMD26 ( I'm sure it will fit 2007 as well).
Pure Power! EHP® Lifetime Oil Filter CLEANABLE & REUSABLE Item Number: 8400.
I won't go into synthetic oils because there are significant opinions on that subject.
Old Nov 22, 2007 | 08:35 AM
Default RE: Performance Possibilities
Gauze or foam air filters always out flow paper, especially when dirty.
You won't get much of anything with spark plug changes?
The H3 actually is one of the few GM trucks w/ adequate brakes right from the factory. I guess more than a decade of criticism about GM truck brakes finally sank in?
I got no idea about the oil filter you reference, but it sounds interesting and I'm gonna look into it.
Old Nov 22, 2007 | 09:11 PM
hilljob26's Avatar
thats good info,i agree on the brakes,they are really nice
Old Nov 23, 2007 | 06:46 AM
I plan on getting the Brisk Spark Plugs, I have used NOLOGY Beru Silverstone with good results. Also looking into the Fitch Fuel Catalyst ( Can't Hurt). I just figured putting out the information to help people have choices for there decisions.
Old Feb 23, 2008 | 12:57 PM
Jhaslup's Avatar
Hey Gunny,
I noticd in your 11/21/2007 post that you mentioned 2 distinct oil filters. Do you prefer one over the other. Based on my research, they both appear to be very similar, from the design and function, all the way to the price. Curious to see if others have gone down this path.
TIA,
Jim
Old Feb 23, 2008 | 01:10 PM
alphadogg's Avatar
Hey Gunny,
How about the skinny on the 08' Alpha? That's if you got nuthin' to do in your spare time.[sm=thanx.gif]
Old Feb 24, 2008 | 12:34 AM
On the oil filters those that I noted are good, but further research I found that Canton Oil filters flow well and filter down to 8 microns and they are synthetic material and have two mileage changes/ratings- 10k and 20k. The Filter cannisterruns around 100 bucks and the filters are about 9 bucks.
Can do on the Alpha, I will post it here.
Old Feb 24, 2008 | 06:29 PM
alphadogg's Avatar
ORIGINAL: TheGunnyRet
Thank you Gunny. Much appreciated. [sm=americanasmiley.gif]
Old Feb 25, 2008 | 04:35 PM
Well you ask for it, (Alpha info)I just want to note that I referenced my data from a 2005-5.3L-323 Gen III/IV series family of engines (LS1 based). GM pretty much keeps the commonality on these engines and mostly the changes/differences are electronic and minor sensor positioning changes. I am not familiar with the Newer GM family of engines. So most of this information is from basic reading analysis. Being where I am, I can not get specific verifications. Asking a good GM performance guru to verify my information would be a safe thing to do.
NOTE: I will not be upset or offended if questioned that some of this informaion is incorrect. Thanks
H3 ALPHA info:
Displacement: 5328cc
Assembly Site: Romulus, MI
Configuration: overhead valve (2 valves per cylinder).
Horsepower: 300 @ 5200 rpm
Torque: 320 lb-ft @ 4000 rpm
Applications: Hummer H3 Alpha
Note: LH8 is the non-AFM version of LH6
http://chevy.off-road.com/chevy/Product+Releases/COMP-Cams-Tri-Power-Xtreme-Cam-and-Programmer-Kits/ArticleStandard/Article/detail/307691?searchString=GM%205.3%20liter%20engine%20Ca ms%20performance
http://www.compcams.com/information/whatsnew/Files/COMPXFIGenIIITruckCamshafts.pdf
http://www.granatellimotorsports.com/product_display.php?gid=101
http://www.granatellimotorsports.com/ignition_cat.php?cat=3
http://www.gmhightechperformance.com/tech/0601htp_gen_3_gen_4_cylinder_head_guide/index.html
http://www.enginebuildermag.com/Article/1096/Gen_III_GM_Small_Block.aspx
http://www.hotrodlane.cc/trucktopcover.html
The new COMP Cams® XFI™ Truck camshafts for GM Gen III engines are compatible with the factory computer systems and wiring but deliver the best performance when used with upgraded COMP Cams® valve train equipment, including valve springs, retainers and locks. COMP Cams® XFI™ Truck camshafts (PN# 54-450-11 and PN#54-452-11) are built to deliver significant power gains in the mid and upper RPM range. COMP Cams® XFI™ Truck cam (PN# 54-451-11) for 5.3 and 6.0-Liter GM Gen III truck engines produces even larger mid and upper RPM range power but works best on vehicles featuring performance exhaust systems.
CRANE CAMS:
LS1 Aluminum Roller Rockers
"Quick-Lift™" design delivers up to 20 HP! "Quiet-Design" does not trip knock-sensor. Fits under stock rocker covers.
QUICK-LIFT ALUMINUM ROLLER ROCKER ARMS
[color=#0000cc]An easy bolt-on that’s good for 15-20 horsepower gain in LS1/LS6 engines. These highly efficient Crane rockers employ Crane’s unique new “Quick-Lift” design technology that accelerates valve events for more flow and improved performance. By relocating the pushrod seat down and in, Crane engineers have created a “variable ratio” rocker arm that begins with a ratio of about 1.78:1 and converges to a standard 1.7:1
wizwalker
May 5, 2013 08:29 PM
Caraddict
Dec 12, 2011 06:55 AM
Patrick
Oct 27, 2010 12:14 PM
Mikeoj338
Aug 19, 2008 10:43 AM
gts88fiveOh
Nov 25, 2005 06:34 PM
