Pedal to the floor... BRAKE pedal!
Old Apr 9, 2008 | 07:35 PM
AMG55's Avatar
Default Pedal to the floor... BRAKE pedal!
It seems that my H3's brake pedal slowly goes to the floor as I depress it as if the brake line is leaking somewhere...
example 1: stopped on an incline, trans in Neutral, foot on the brake. slowly the brake pedal goes to the floor and the car rolls back. so I put on the e-brake. no biggie... maybe
example 2: stopping down a hill.... this is dangerous, the pedal slowly goes the floor and the car just keeps rolling.
example 3: 200-300 ft (roughly) normal stop from 25-30 mph by depressing on the brake pedal with normal constant pressure. The pedal again goes to the floor (slowly)
Brake fluid level is OK
Any suggestions or advice?
I think I shouldn't brave it and drive to the dealer right?
This is a frustrating end to a long day...
Old Apr 9, 2008 | 07:39 PM
Evadd's Avatar
Default RE: Pedal to the floor... BRAKE pedal!
if it's still under warranty (and it likely is, as an 07), i'd take it in. i definitely would NOT drive it around like that. personally, however, i would drive it to *my* dealer - but that b/c he's literally 2 blocks away. if i were you, i'd get it towed.
Old Apr 9, 2008 | 07:40 PM
alrock's Avatar
Wow, uh, I'd be calling for a tow right away. You don't want to be a 5000 lb missile in traffic.
I'm not a brake expert by any means, and I'm sure some will come along, but obviously you are losing pressure somewhere. Maybe it's not enough to show a drop in brake fluid yet. Or maybe there's air in the line, or contaminated fluid.
You made it to the end of the day without getting hurt. That counts for a lot. Tomorrow, the dealer gives you a loaner and fixes it up. That'll be a good day.
Old Apr 9, 2008 | 08:03 PM
Ryan Graham's Avatar
Sounds like a bad master cylinder, but with all the motors/servos/ and modules attached to it I'm not sure if there's other places the fluid could bypass so I dont know what they'll replace. Keep us informed.
Old Apr 9, 2008 | 08:42 PM
Lots of possibilities; diaprahm in the master cylinder, air or moisture in the line, etc. My guess is the master cylinder. Pretty soon you should notice a drop in your brake fluid level. If you pump the pedal you should get some more stopping power but that is a short term solution. Get your truck in asap.
Old Apr 9, 2008 | 09:33 PM
AMG55's Avatar
thanks guys - that's what I've been doing when I needed extra stopping power - pumped the brake pedal.
gotta call the dealer tomorrow - definitely don't want to be a 5000 lb missile in traffic... [&:]
ill keep u guys informed.
Old Apr 9, 2008 | 11:20 PM
Good luck, check your brake fluid and be safe.
Old Apr 10, 2008 | 05:48 PM
Forney's Avatar
If you have to you can shift from Drive down to slow you down, we had the brakes go out on a cherokee once and drove through the city of Lincoln with no brakes
Old Apr 11, 2008 | 09:57 AM
AMG55's Avatar
ORIGINAL: Forney
yup ive had to do that a few times just to be safe...
bringing the car in tomorrow, hopefully the loaner will have working brakes
Old Apr 14, 2008 | 01:41 PM
AMG55's Avatar
guess what - the brakes fixed themselves on the day I brought it in. The dealer agreed to keep looking however and I'm "stuck" with an 08 Chevy Silverado LT 4x4 Crew Cab.. pretty sweet truck
