Passenger Rear Window Issues
Old Feb 1, 2011 | 10:47 AM
ARonBoard's Avatar
Default Passenger Rear Window Issues
So.....
Went out with some friends and passenger rear window was rolled down (nothing unusual) and it would not go back up. I pulled the door apart and it seems the top perch of the cable pulley system broke off!! I cannot even get the window to close all of the way when pushing up on it.
Do you need to buy a whole window regulator kit to get this thing working again?
How hard is this installation?
Old Feb 1, 2011 | 12:37 PM
calif phil's Avatar
Yes you need a new reguator. They are not hard to install.
Old Feb 1, 2011 | 01:02 PM
ARonBoard's Avatar
Phil,
I really appreciate the response. Any special tools needed or is it straight forward plug and play with a couple screws and nuts?
Old Feb 1, 2011 | 08:03 PM
calif phil's Avatar
It's pretty straight forward. The only tool you should need is a door panel trim remover to pop the panel off. You might want to go to your local GM dealer and pick up a couple of extra door panel clips. Sometimes they break upon removal.
Old Nov 8, 2013 | 01:09 PM
jar9046's Avatar
2008 H2 rear window regulator. If you need one it is an easy job. Takes about one hour. No special tools needed. Bought mine here on Amazon.com.
ACDelco 15771354 Hummer H2 Rear Passenger Side Window Regulator Assembly. About $170.00
hummerhack
Dec 17, 2014 02:25 AM
remmy
Jun 7, 2014 08:06 PM
Estrates
Feb 8, 2013 03:03 AM
th3_villain
Oct 7, 2009 08:38 AM
tavion2378
Oct 17, 2008 06:21 PM
