Oil seal of rear differential broken
Old Aug 15, 2007 | 08:39 AM
danist's Avatar
Default Oil seal of rear differential broken
Hi,
I´m from Germany and yesterday I was at the dealer for the 30.000 km (20.000 miles)inspection of my H3. They said that the oil seal ring of the rear differential is broken and has to be replaced. My question: Is it normal that it is broken after 20.000 miles? Well, okay I do offroad very often but it should last longer.
Thanks,
Daniel
Old Aug 15, 2007 | 08:57 AM
HummerGuy's Avatar
Default RE: Oil seal of rear differential broken
I have almost 40k miles on mine and haven't had anything leak. My differential is completely dry. Then again, I don't off-road very much
Old Aug 15, 2007 | 09:34 AM
An oil seal is a part. Parts are sometimes defective, or not installed properly from the factory (egad, factory rat not doing their job? I've never...........) or subject to abuse and just break. 20k is not a normal life span, but that is why a new car warranty is a valuable asset. I had 160k miles on my last GMC and had no seal problems, rear differential or otherwise. I have had brand new seals go bad in a few thousand miles???? Roll of the dice, but I would bet that after the dealer replaces your seal you should have no further problems. Say hi to my cousins at Rentschler Moving in Deutchland Bro.
Old Aug 15, 2007 | 02:40 PM
HERHMR's Avatar
Danist,
My 2007 H3 auto only has 4,400 miles and it has been leaking one drop of oil a day, about half the size of a dime of oil, for a week now. Its appears to be dripping around the differential area. The oil appears clear with a tiny drop of black, guess this could be road dirt....
I have a call into the dealer for an apt and I will mention the seal part. Did they keep your H3 over night or days????
Thanks for your post!
Sheree`
Purchased: March 2007 (Lux Pkg)
4,400 miles
Normal drive in 4^
I have a call into the dealership to set up an appointment.
Old Aug 15, 2007 | 04:28 PM
danist's Avatar
Thanks for your answers!
@HERHMR: No, they just made the normal inspection, I have to make another appointment for next week.
Old Aug 15, 2007 | 04:52 PM
Desert Dan's Avatar
Is it the pinion seal (by driveshaft) or the outer axle seal (by the reartire)?
either one it is an easy fix esp under warranty.
Old Aug 15, 2007 | 05:34 PM
danist's Avatar
I think it´s the pinion seal but I´m not completely sure.
Old Aug 15, 2007 | 05:39 PM
Muddydawg75's Avatar
That's really luck of the draw.... I had a set of gears put in by a great shop... lasted until I broke the pinion.... second set they put in the pinion sealleaked.
Even if it isn't under warranty it isn't that hard of a repair.
Old Aug 24, 2007 | 04:29 PM
HERHMR's Avatar
Hello!
I justreceived my H3 out of the service dept. They had to replace the rear diff gasket, which is under warranty...... only 4,400 miles on it!
HERHMR
2007 H3 w/lux pkg
Boulder gray
Oregon
[sm=bling.gif]
[IMG]local://upfiles/2986/3605C451F5824132BD88837FEA1B57FA.jpg[/IMG]
Old Aug 24, 2007 | 07:18 PM
Nice ride, great pic. Welcome HERHMR. [sm=smiley20.gif]
motley1987
Jan 10, 2022 01:08 AM
No more Jeeps
Jul 2, 2020 03:37 PM
man-of-war
Apr 24, 2014 07:28 AM
drtom
Jan 17, 2011 09:23 PM
hummer07
Nov 18, 2008 10:46 AM
