Oil Plug Size
Old Nov 10, 2014 | 09:39 AM
Max01's Avatar
Default Oil Plug Size
Does anyone know the oil plug blot size on the H3T Alpha 5.3L, V8?
After doing an oil change this weekend I am tired of removing the skid plate and having the oil hit the cross member on the frame and make a huge mess.
I decided I am going to order a Fumoto oil drain with the hose.
I measured the bolt and know it is 12mm but I don't know the thread pitch. Has anyone purchased a fumoto and know the size or if someone is doing an oil change soon can you measure the pitch between threads.
Old Nov 10, 2014 | 10:26 AM
Bunger's Avatar
I have installed a Fumoto # F107N
F107N | Fumoto Engine Oil Drain Valves
I have a I5 engine. but I think it's the same for the alpha V8.
Old Nov 11, 2014 | 04:27 PM
Synthetickiller's Avatar
These are excellent. I've used them on two vehicles.
Neither has ever leaked. I'd say it takes a 1/10 of the time it used to take to change my oil.
OP, can you confirm that it fits after getting the valve?
Thanks.
Edit. The valve also works for the H3 Alpha (or any of the 5.3L V8s) and the H2 6.2L as well.
Old Nov 11, 2014 | 07:55 PM
Fumotos here also. Saves time and mess!
Old Nov 18, 2014 | 09:02 AM
arcaro's Avatar
When I went to change my oil with the fumoto plug, oil just trickled out. Took a long time to drain the oil. It must be clogged or something.
Old Nov 18, 2014 | 02:51 PM
Did you unscrew the oil cap on the engine first? I ask because I've pulled that stunt before & wondered why everything took so long. I hope it's that & not something major.
I've had 2 of these (not on hummers, yet) & they drained quickly.
Old Nov 19, 2014 | 08:05 AM
arcaro's Avatar
[QUOTE=Synthetickiller;319619]Did you unscrew the oil cap on the engine first? I ask because I've pulled that stunt before & wondered why everything took so long. I hope it's that & not something major.
I've had 2 of these (not on hummers, yet) & they drained quickly.[/QUOTE
It drained fast before without unscrewing the oil filler cap.
DOC4H
Aug 16, 2017 07:59 AM
kyle100
Jul 6, 2010 01:43 PM
Broken Halo
Mar 7, 2010 08:02 PM
hummer07
Nov 18, 2008 10:46 AM
nate_b
Mar 7, 2007 11:31 PM
