OEM MUDFLAP INSTALL
ORIGINAL: Dennis
Yeah..you better take them off..It will make life so much easier on the install..I did the OEMs too.
ORIGINAL: ZX10R
AWE man... Thanks Dennis. Also Did you feel comfortable drilling the holes? Is there any rust etc. resulting from drilling that you noticed.
ORIGINAL: Dennis
,,,The fenders are plastic..
I did them myself, left the tires on and had no problem... it was a tight squeeze and had to manipulate the drill a little bit to get it in there, but It took me only about 30 mintues to do all 4 tires. I will recommend on the front to turn the wheel all the way to one side to give you room to work behind it, and turn it the other way to do the other side. So far I'm happy with the mudflaps, but I wish the covered more area. The dirtiest part of my H3 is where the fender extends out on the rear doors....even driving a few blocks gets that real dirty.
Installed mine with no problem. Used a Polish cordless drill. Clamp you drill bit with a pair of Vise Grips, apply a little pressure and spin the Vise Grips around between the fender and the rear tire. Probably wouldn't work on steel, but Ok on plastic fenders.
