OEM foglight replacement 08 H3
Old Aug 4, 2015 | 01:57 PM
sinful7's Avatar
Default OEM foglight replacement 08 H3
Not sure if this is the right place to ask this, but my drivers side fog light is smoked the stock bulb blew up lol really.. and it melted part of the plastic so Im going to replace it with a new one.. maybe the stock owner had higher wattage I am not sure, but im going to put stock stuff back on.. my question is I looked under and I see 3 bolts to take it out, however talk about a nightmare to do this, is there some secret to get these out cause a body shop told me its a whopping 20-30 min ordeal and I tend to think to do it that quick ill have to remove the bumper..
Old Aug 4, 2015 | 01:59 PM
sinful7's Avatar
ok I know its been a whole 2 mins from my post but I ran outside and checked the other bulb that's still in and yeah they were higher wattage 100w bulbs.. so that explains why it melted when the bulb went out.. so I did unplug it till I get this fixed and I can put correct bulbs in.
Old Aug 5, 2015 | 08:54 AM
MOVED to the H3 Section...... where threads about H3s go.
Old Aug 5, 2015 | 01:08 PM
H3Ray's Avatar
Same happened to me previous owner had higher watt bulb. Go back stock.
Old Aug 5, 2015 | 06:07 PM
rsc's Avatar
rsc
On one of the other forums there is a guy making new brackets and putting LEDs in there. Lots of pictures, might give you some clues. Search "H3 LED fog light brackets" by adventr.
Old Aug 14, 2015 | 08:32 PM
Happy Hummer's Avatar
Actually my oem Fog Light fell in the bumper back some time ago and it was easier too just remove the whole assembly and take it to the kitchen table for a rework.
The PO decided 100 mile per hour tape works better than bolts. Clearly they replaced the outer skin of the bumper and left the entire broken inside honeycomb structure still there.
Here's some pics. ...
https://sites.google.com/site/happyhummer01/front-bumper--fog-light-repair
Old Aug 15, 2015 | 04:41 PM
RKSmith163's Avatar
I replaced my Drivers Side Fog light. I removed the wheel liner. The bolts are still hard to get to. I had to loosen a bracket to get to one of them. Overall not too hard to do. Good Luck
Old Aug 19, 2015 | 09:51 PM
skeeter's Avatar
lifetime led makes a replacement plug and play led light
bosoxdew
Dec 5, 2014 02:39 PM
SundownAudioNY
Sep 6, 2011 03:02 PM
CWS
Oct 2, 2010 06:30 PM
JDTDBD
Feb 12, 2010 09:16 PM
Koolaid
Apr 11, 2009 12:43 AM
