Noise from steering column?
Old Apr 13, 2012 | 05:13 AM
itsxthexslim's Avatar
Default Noise from steering column?
Ok need some help if possible. My 03 h2 is all of a sudden making a groaning noise when ur parked and turning wheel. Truck was just in shop and did not mention bearings at all. The noise becomes a squeak when you go slow and turn. I'm lookin to sell truck so this is something I need to fix. Thanks guys
Old Apr 13, 2012 | 06:17 AM
LoJac963's Avatar
are you sure its from the steering column and not the power steering pump or box?? I would check the PS fluid first just to make sure its at the appropriate level-maybe an easy fix.
Old Apr 13, 2012 | 03:16 PM
bflorin's Avatar
Its the pump. Try giving it a little throttle while lightly riding the brake- Spins up the pump a bit for additional pressure.
The squeak is most likely the belt slipping on the pump. Belt could be warn/dirty, tensioner could not be holding the belt the tighest possible, possible the pumps failing/starting to get alot of resistance spinning slipping the belt. Could be a combination of all of the above.
If that pump takes a ****, dont even think about putting a stock replacement back in it. Call AGR Performance and order one of their pumps, doesn't cost much additional. You wont believe the diffrence it would make.
quadblaster240
Mar 30, 2012 07:48 PM
bigdog100
Feb 6, 2012 07:35 PM
Hummer2006h3
May 30, 2011 02:01 PM
patricktheelder
Jul 4, 2010 05:46 PM
psych0
May 1, 2009 08:15 AM
