No power to stereo... Ideas?
Old Aug 29, 2014 | 07:30 PM
Rob R's Avatar
Default No power to stereo... Ideas?
I have an '03 H2, purchased used around 2 years ago. It has a pretty massively upgraded stereo system - an Alpine IVA-W205, all kinds of amps under the rear seat, backup camera, nav system, the works.
Today I drove my son to an event, parked, and when I started it back up, everything except the stereo works. It seems like it simply has no power. Note that ambient temp around here is ~75 degrees and dry today, so I don't think weather played a part.
After I got home I tried several times, no luck. I pulled the Radio, Radio Amp, and two inline (added by stereo installers I assume) fuses, all look fine.
Unfortunately, it's a flush mount stereo so I can't even pull the unit without getting the front display to slide-down (the screws are inside).
Any ideas on what else to check?
Old Aug 30, 2014 | 06:12 PM
LoJac963's Avatar
There has to be a way to get the screen down without power, you need to check the harness with a test light or multimeter and see if it is getting power to the head unit.
Old Sep 1, 2014 | 09:43 AM
Rob R's Avatar
Well, the mystery is solved.
I couldn't find a way to get the stereo out (it is flush all around) so I started pulling open the dash. Couldn't get the center surround out with the center console in place, so I started working on that. When I got the console bin out, I noticed it had two wires attached to it.
Apparently whomever did the aftermarket stereo equipment put a kill switch in there (reason unknown) and it had gotten bumped into the off position.
One flip of the switch and I'm back in business.
Old Sep 1, 2014 | 03:28 PM
LoJac963's Avatar
At least it wasn't anything major, glad you found the switch!
hmer
Jul 29, 2014 12:10 PM
Torcher
Jul 15, 2013 12:24 PM
Ericp501
Feb 4, 2011 07:49 AM
Tonyg41
Jan 29, 2010 01:41 PM
Alukavi
Mar 19, 2009 07:20 AM
