No Air
Old Jun 2, 2008 | 11:58 PM
hummer's Avatar
Default No Air
My air conditioner/heat stopped blowing!!! When your going down the road it lets air move through the vents ( 0 on control) but thats it. Hasanyone else had this problem?!
Its 90 degres and i aint got no A/C HELP!!!!!!!
-Thanks
Old Jun 3, 2008 | 12:13 AM
General's Avatar
Default RE: No Air
Your hair conditioner ??
Sorry, maybe only a blown fuse?
Old Jun 3, 2008 | 12:15 AM
Default RE: No Air
Check fuses first.
Old Jun 3, 2008 | 10:36 AM
hummer's Avatar
Default RE: No Air
I checked the fuses and it didn't work. I couldn't find one that said fan, a/c, or anything that sounded like it had anything to do with the air.... When you push the button with the snowflake on it you can hear the A/c come on its just not blowing out!
Old Jun 4, 2008 | 09:36 AM
RealJeep's Avatar
Default RE: No Air
This is a bad problem with the H3s and Canyons!!! Mine has been back twice for this issue. (Search posts "bad smell or burning smell from A/C).
The problem is there's a cheap plastic connector that connects the A/C fan wiring to the ballast resistor on top of the evaperator housing behing the glove box. The ballast resistor restricts voltage to the A/c fan so it can run at different speeds. Like any electrical resistor (ie..your toaster) it creates heat, the heat melts the cheap plastic connector and it stops working. Sometimes it blows the fuse, sometimes not. The next time it melts and the dealer replaces it with another cheap plastic connector I'm going to fix it right myself with some high temp electrical connectors.
Old Jun 24, 2008 | 05:16 PM
hummer's Avatar
Default RE: No Air
Ok, they fixed the air and told me the same thing RealJeep said...(Thanks RealJeep)
Sorry it took so long to update you guys on what happened but iv been at the lake for the last few weeks playing with my new boat.....
Old Jun 26, 2008 | 07:30 AM
RealJeep's Avatar
Default RE: No Air
No problem hummer. GM has known about this issue for a long time but until the plastic plug melts down they won't replace it. I'm running the **** out of mine just so it will hurry up and melt so I can get it replaced.
mastercraft88
Jan 23, 2010 09:37 PM
provenceman
Feb 9, 2009 10:51 AM
fastboatnut
Jan 20, 2009 07:41 AM
BMJM100
Jan 10, 2009 02:46 PM
