NEW H3 LEVELING KIT
Old Feb 13, 2007 | 06:16 PM
Smitty's Avatar
Default NEW H3 LEVELING KIT
ReadyLift came out with a new 2" leveling Kit at the Sema show. It does the exact same thing as the Truxx kit but it is Half the Price. I would highly recomend it to anyone who wouled like to raise up their nose a bit.
Jake
www.stallioncustoms.com
Old Feb 13, 2007 | 06:40 PM
HummerGuy's Avatar
Default RE: NEW H3 LEVELING KIT
Does it work the same way as the others with the replacement keys?
Is this the one you are talking about?
http://www.stallioncustoms.com/h3-hummer-lift-kit.html
Old Feb 13, 2007 | 06:58 PM
Smitty's Avatar
Yes thats the one. I just took the truxx kit off mine and put this one on over the weekend. This kit actually seems to have a bit better ride also.
Jake
Old Feb 13, 2007 | 09:18 PM
Larain60's Avatar
How hard is the kit to install?
Also are there any cons after installation?
Thanks.
Old Feb 14, 2007 | 06:30 PM
Smitty's Avatar
The only Con is you might loose 1 MPG beacusethe truck wont be as aerodynamic, but i think it is worth it.
Old Feb 17, 2007 | 02:35 PM
jm4490's Avatar
Who makes this kit? Brand name? How much does the ride actually change?
Old Feb 17, 2007 | 03:09 PM
importkiller's Avatar
actually there are more cons than just losing some MPG!! There is no brakcet to relocate the diff...correct? Sothis kit WILL be changing the cv-joint angles....which will lead to premature wear...the same way that cranking the t-bars will do.
Old Feb 17, 2007 | 05:54 PM
bmbenear's Avatar
Put the Ready Lift on my 07 H3. Really like the look and the ride seems pretty much the same. Cost $350.00 installed with front end alignment. I think the kit was $175.00. Very, very pleased.
Old Feb 28, 2007 | 07:09 PM
hummer1's Avatar
You are correct is stating the kit changes the cv-joint angles. Anyone sell a kit to lower the dif. to change the cv-joints to factory spec's. Any info would be great. Hummer1
Old Mar 11, 2007 | 08:53 PM
novasaigo's Avatar
I could not figure out how to delete this one. See next post for images
