need help with turbo build
Old May 19, 2016 | 07:29 PM
fierofan25's Avatar
Default need help with turbo build
I have a t3 turbo installed on my wifes 07 hummer h3 with 3.7l engine. I am having trouble finding someone that can tune the pcm. Please help thanks
Old May 20, 2016 | 06:18 AM
PCM of NC
Old May 20, 2016 | 07:06 AM
rsc's Avatar
rsc
PCM of NC can do it, get the live data logging to provide them the feedback on the tun. There may be someone local to you, check Craigslist as there might be someone local to you advertising tuning. Plenty of folks running around trying to recoup the money they spent on a tuner that could help you out.
Old Jun 8, 2016 | 09:38 PM
fierofan25's Avatar
I ended up using a company called lime-swap.com. The guys name is Jeremy super nice guy and he did a good job on the tune. started right up and it runs ten times better. The only problem is it runs a little lean sometimes and throughs a misfire code. Not sure if its the tune or fuel pump issues. only does it when i mash the peddle at a full stop and not all the time. Only running 5 pounds of boost.
fierofan25
May 20, 2016 06:23 AM
euc
Hummer H1
Jul 26, 2014 09:40 AM
philfischer
May 3, 2011 11:19 AM
rod
Aug 8, 2006 12:31 AM
rod
Mar 27, 2006 11:05 PM
