Need help installed K&N AIR intake
Old Jan 1, 2009 | 02:26 PM
driller's Avatar
Default Need help installed K&N AIR intake
I need help I installed a K&N air intake system and now my check engine light came on any Ideas? Thanks
Old Jan 1, 2009 | 04:11 PM
Crash's Avatar
Default RE: Need help installed K&N AIR intake
Mass air flow sensor in the intake tube is now covered in oil from the K&N.. Take the MAF out, wipe it down and see if clears it up.. If not, new MAF..
Old Jan 1, 2009 | 08:23 PM
lucky19942001's Avatar
did u disconnect the battery be4 install cause u schould have unless u just put the k&n filter in. if it's the package then u need to dis connect the battery be4 install. like in first reply if u did not pad the oil off then u got the maf.
Old Jan 4, 2009 | 03:56 PM
driller's Avatar
Thanks for the reply's I bought a new maf and dissconected the batterie the check engine light went off for about 25miles then came back on so i got the code checked and it says that the engine is running to lean will this hurt the engine it dosent stall or have any other issues other then a little pop from the cold air intake nothing loud any hel would be great I am just seeing if i should switch back to the old air intake thanks
Old Jan 4, 2009 | 10:41 PM
dont no what to tell u,when i wanted to install a air intake system i went with true flow cause there is no need to take out the factory air box so u dont need to touch the maf. i love it and have not had any problems in the year it's been in and i also use the k&n air filter instead of the true flow filter cause i like the k&n filter better. so i suggest fo back to the stock or go wth something like a true flow and replace everything but the air box. good luck
[IMG]local://upfiles/4035/9E45F8F13A3D4BD0902DDA7DD92B8A66.jpg[/IMG]
Old Jan 5, 2009 | 07:24 AM
D VADER's Avatar
I have the same K&N filter and a modified airflow. My engine light has never come on. Wash your filter and easy on the oil!
Old Jan 5, 2009 | 01:18 PM
ORIGINAL: Crash
NEVER touch the MAF with anything, do not even think of wiping it. A wipe will wipe em out!
Use MAF cleaner only, and follow the directions.
Old Jan 5, 2009 | 01:22 PM
ORIGINAL: driller
It will take about 100 miles + to get your PCM to learn the knew fuel mixtures it needs. The pop you hear has always been there, but your K&N plastic open [:@] system know lets you better hear the diaphram shutting when you shut down.
Closed systems RULE! [8D][8D]
Old Jan 5, 2009 | 01:29 PM
D VADER's Avatar
ORIGINAL: Doc Olds
ORIGINAL: Crash
They don't call him Doc for nothing!!
I have a can in the garage.
Read the directions? Like we read our manual?
Old Feb 25, 2009 | 12:44 PM
sattv's Avatar
My check engine light is on AGAIN 07 H3 I think it's time to try maf cleaner
