need help with hooking up subs and amp
Old Feb 24, 2012 | 08:54 PM
firefighter1133's Avatar
Default need help with hooking up subs and amp
I have a 08 Hummer H3 Adv. It has the monsoon system without onstar.
I am wanting to keep my factory headunit for now because i like the 6 disc changer.
What will be needed to hook it up?
I've hooked up systems with aftermarket head units, but never a factory one. Does the Monsoon have RCA plugs in the back to power the factory amp?
Is there anyway I can unhook the stock sub but the amp still power the door speakers?
Thanks in advance for all help.
Old Feb 24, 2012 | 11:07 PM
Hummphrey's Avatar
You will need a Line Output Converter to give you RCA Outputs. The factory player will not have them. You can use the factory amp to make your connections. Since you are asking about unhooking the factory sub, Im assuming you're going to remove the rear side panel to get to it (that is where the factory amp is). Get a good LOC from a local stereo shop dont get a cheap one from wal-mart. It might cost you $20.
You can just unplug the factory sub after youve removed the panel. It has a harness going into it with the speaker wire that can be unplugged so it stops playing.
NoThreePutts
Aug 31, 2011 07:49 PM
twolgrl
Dec 31, 2009 03:36 PM
tangodown
Dec 27, 2009 08:35 AM
JeepeaterH3
Mar 16, 2008 02:44 AM
lax
May 12, 2007 05:10 PM
