Need help
Old Aug 13, 2009 | 10:42 AM
aarni's Avatar
Default Need help
hy friends
need help for my baby
the interior lightning cant be switched off
normaly its dimmed off when i chose „d“ or lock the car
but nothing happends
what could i do now
now i have removed all lamps
is there any relay or fuse defect?
can anybody help?
Old Aug 13, 2009 | 01:11 PM
RKSmith163's Avatar
First, is the thumbwheel near your headlight switch rotated all the way upward. That turns them on but in that case they would remain on all the time. Second, check each individual switch on your doors and rear gate. Sounds like one of these is sticking or not making physical contact with the door or is electrically shorted making electical cantact all the time. Those are the most likely causes and easiest to troubleshoot.
Old Aug 14, 2009 | 08:23 AM
aarni's Avatar
thx
but if the door switch is defekt
is there no information in the display „doors open“?
Old Aug 14, 2009 | 01:44 PM
RKSmith163's Avatar
Originally Posted by aarni
thx
Quite true, Next step is the Dealer to check the BCM
Old Aug 15, 2009 | 08:41 PM
BrickWurX Mfg.'s Avatar
I had the rear passenger door trigger fail. Five dollar part if your out of warranty. Lights did not go out, nor did the dash register. I think they are negative trigger grounded. So while the signal is still correct, the switch can make a connection by grounding due to failure such as moisture. If that makes any sort of since at all.
Check your dash cluster. Then check your switches by pulling them out (torx bit), and disconnecting them . Make sure you don't let the wiring fall back into the opening, major pain. A few forum members have metioned water issues making a connection, specifically on the rear hatch.
Good luck
importkiller
29
Jan 15, 2008 02:51 AM
WOLFGANGSTA
Feb 11, 2007 03:55 PM
crc2k
Sep 1, 2006 04:03 PM
skeeet
Mar 16, 2006 05:21 AM
efrainl956
May 16, 2005 10:46 PM
