mild front torsion bar lift w/bilstein hd's
Old Jan 21, 2012 | 09:38 PM
aaronh3's Avatar
Default mild front torsion bar lift w/bilstein hd's
anyone have any experience doing this. looling to go up to 23" in the front and want to know if the bilstein hd would be ok.
Old Jan 21, 2012 | 10:37 PM
bowtieturninghummerguy?'s Avatar
Default you tube vid on torsion lift.....
as well as several posts on this forum here about same do a search.
Old Jan 21, 2012 | 11:54 PM
rsc's Avatar
rsc
Cool
Why 23"? You could go higher ya know. Personally, I would get the H3's offroad/adventure shocks and a couple of washers, if extended length bothers you, instead of the Bilsteins which are longer but softer.
Old Jan 22, 2012 | 06:05 AM
08JJ's Avatar
Good choice on the Bilstein's....I went with the 1500's and the ride is great on 35's
Old Jan 22, 2012 | 06:35 AM
Hello and Welcome from MI!
Please, use the SEARCH function at the top of this page and enter "torsion bar bilstein". There are about 50 Threads on this exact subject. Read through them and see if they answer any of your questions and concerns.
Old Jan 22, 2012 | 08:41 AM
aaronh3's Avatar
i did read through them, thats why i asked about the bilstein hd's specifically as it seems as if there is not alot reviews of people that have used them. i may just use the 5100's instead.
Old Jan 22, 2012 | 04:11 PM
Sorry about that! By the way Bilstein does not stand behind their shocks. I had a 5100 leak with only 12k on it and the warranty was denied because I used the vehicle OffRoad!!!! Even though the website states: "ideal for heavy hauling or occasional off-road use".
I haven't seen a listing for a Bilstein HD for the H3 (Stock or "t-bar cranked") so I assumed you ment the 5100s. The only options as of right now are the :
Part Number: 25-176407
Setting: 5160 Series
Position: Front
Descriptor: Front Lifted Height: 0-2.5"; Torsion Key Lift
*Collapsed Length (IN): 12.83
*Extended Length (IN): 16.3
*Collapsed Length (MM): 326
*Extended Length (MM): 414
Old Part Number: F4-BR5-H640-H0
Part Number: 24-186643
Setting: 5100 Series
Position: Front
*Collapsed Length (IN): 12.54
*Collapsed Length (MM): 318.5
Old Part Number: F4-BE5-C153-H0
Part Number: 24-187091
Setting: 4600 Series
Position: Front
Descriptor: Standard Suspension
Old Part Number: F4-BE5-E672-H0
Part Number: 24-185615
Position: Rear
Descriptor: Rear Lifted Height: 0-1"
*Collapsed Length (IN): 16.18
*Extended Length (IN): 26.2
*Collapsed Length (MM): 411
*Extended Length (MM): 665.5
Old Part Number: F4-BE5-6254-H6
Old Jan 22, 2012 | 06:27 PM
aaronh3's Avatar
hanks for the info, shockwarehouse lists the hd's for the h3 but they list them for stock height.
Old Jan 23, 2012 | 02:14 PM
The list above is directly from Bilstein/Cognito. I would ask a lot of questions or get the model # and look them up on the Bilstein/Cognito site and see if they match the length, and the mounts (upper and lower) of the above mentioned shocks.
Old Jan 23, 2012 | 10:18 PM
mgoblue85's Avatar
Thumbs up
We did the T-bar lift and have it at 23-1/2". Installed the 5100's with 1/2" extended bump stops. Also installed Bilsteins on the rear. Rides great and I would recommend this to anyone wanting to level their rig.
Panzerh2
65
Nov 4, 2016 12:15 PM
sinful7
Aug 10, 2015 07:05 AM
sinful7
Aug 4, 2015 01:52 PM
blademaster103
Feb 1, 2014 04:42 PM
Todd Edge
Jun 6, 2013 05:09 PM
