Metal Scraping Noise Only in Reverse
Old Nov 2, 2016 | 05:42 PM
Manson75's Avatar
Default Metal Scraping Noise Only in Reverse
I hear it when I'm backing into a parking space or backing into my garage. I first thought it was the metal guard around the disc brakes catching, but I jacked up the truck and spun the wheels around and couldn't replicate the noise. And it clearly only happens when I shift to reverse and start moving. And I can tell it is making revolutions, a repeating sound that can go slower or faster.
Old Nov 2, 2016 | 07:00 PM
happythree's Avatar
guess!, loose pads.touch brake lightly going back, see if?
Old Nov 3, 2016 | 10:27 AM
Cat heat shield, they get old, corroded and rattle under low speed load. Get under there when it's cool, and bend it away from any contact.
If you doubt it, lay on the ground next to the truck (Keep away from tires!!) while someone slowly backs up a slopped driveway, you can then pinpoint the source.
Old Nov 3, 2016 | 01:31 PM
lostsoul77's Avatar
mine was the heat shield for the oil pan or transmission pan....was rubbing the driveshaft
Old Nov 3, 2016 | 02:45 PM
That has happened with the gas tax skid too.
Manson check your drive shaft for radial scraps (shiny ).
Old Nov 3, 2016 | 06:38 PM
Manson75's Avatar
I'll try those, thanks for the replies!
also, it only happens when I engage the clutch in reverse, weird
BlueH3
Mar 8, 2014 12:56 PM
hulkh3
Sep 12, 2012 08:02 AM
chevydeth
Sep 5, 2012 02:25 PM
Rothchild
Sep 8, 2011 02:01 PM
dazeyhumm
Nov 4, 2007 12:09 PM
