May buy 06 H3 143K miles $7400, head question.
Old Mar 22, 2014 | 12:20 PM
  #31
Murray H2's Avatar
Common or not it happened to me. I'm sure every Hummer specialist is not an expert. Oh well, all fixed. Thanks for your input.
Old Mar 22, 2014 | 12:55 PM
  #32
Originally Posted by Murray H2
Common or not, it happened to me. All fixed. Something to think about.
You have no clue as to what "fixed" it!
I've been running service departments for almost 30years at different auto repair facilities and I have seen it all. I have worked with hundreds of technicians over the years, and I have yet to find 1 that is correct at diagnosis 100% of the time.
For example the tech says cyl head needs replaced. I contact the customer to get approval and get the new cyl head for the tech to install.
Tech installs the new cyl head and rechecks, code returns, now the tech says it needs new plugs, and that doesn't work. Then it needs new coils, and that doesn't work. Then it needs new injectors, which repaired the vehicle and the code doesn't return.
Bottom line, I charge the customer for only what fixes the vehicle, and eventually I send the tech packing due to incompetence!
In your case, you only see on receipt that they replaced the cyl head, however they ONLY charged you for the cyl head, but installed more parts at no charge to you, to fix it properly. Happens all the time, that is why I always recommend getting a second opinion.
Old Mar 22, 2014 | 01:14 PM
  #33
Murray H2's Avatar
Allright guys. This was simply put to let others know they are not alone in the mystery of the problem. Two dealers, two responses, somebody fixed it. Was told the same thing by both dealers. Whatever IT was, it can be taken care of. Thanks for all the input.
Old Mar 22, 2014 | 01:25 PM
  #34
Originally Posted by larry0071
It's been 5 days and 300 miles and that code still isn't back. I tried letting it sit in the driveway to idle for 12 minutes to try to get it to trip the code and got nothing. For now I'm going to ignore that until it comes back. I did run a full tank of Sunoco Ultimate with Lucas injector cleaner since the light came on, so maybe that cured it?
Today I stopped and got CRC throttle body cleaner and CRC air sensor cleaner. Doing the cleansing on those two items is on my weekend chore list. I have another issue that I'll start a new thread on.
Yes, you can certainly rule out the cyl. head ("sticky" injector instead). Great choice on the tb & maf cleaner. Take your time and enjoy a few beers during your "chore", your rig is gonna like it when your done.
atari800
Jan 16, 2015 01:02 PM
Disnydad
Aug 8, 2008 03:43 PM
SEASIDEGRAPHIX
Jul 24, 2008 10:48 AM
MRDM1
21
May 17, 2007 02:10 AM
jen813
22
Aug 10, 2006 01:29 AM
