Manual 5 speed?
Old Feb 22, 2007 | 10:43 PM
machines's Avatar
Default Manual 5 speed?
My shift up light doesn't always light up, any suggestions?? I tried running first gear to 20 mph (sometimes light goes on at 10mph to shift up and other times it doesn't come on at all, even if the engine is running hard and it is time to shift.
Machines
Old Feb 22, 2007 | 11:48 PM
Hummer Guy's Avatar
Default RE: Manual 5 speed?
hmm..not sure. Do you need the lights? i know i know, if you're going to have it, it may as well work correctly...good point..have the dealer check it out.
Old Feb 23, 2007 | 02:27 AM
Linus Gump's Avatar
The light is programmed to come on at the optimum time to shift for economy.It is based on certain engine parameters from the way you are driving at the moment. Try driving like you have an egg under your foot and see what happens. If you drive this way consistanty, it may surprise you with better milage. Or, just drive the way you normally do, but with more consistnacy and the the light should become more predictable.
Old Mar 2, 2007 | 09:13 AM
TANKMAN's Avatar
I have the 5 speed, I noticed if I am just cruising real slow light comes on real early, if I am a little harder on pedal it gives higher mph to get out of each shift.
scubasteve1211
Apr 2, 2012 09:09 PM
Bohomit
18
Oct 27, 2008 11:46 PM
Hummbug
23
May 6, 2008 08:38 PM
mosgerila1
Mar 18, 2007 12:27 PM
khoolhandz
Aug 18, 2006 01:56 PM
