loosing coolant
Old Jul 28, 2015 | 07:25 PM
happythree's Avatar
Default loosing coolant
a few months ago i saw a 2 inch drop in coolant with no hint where it went, no smell,no drip, tranny looks/works ok as normal.
i filled to the line and 2 weeks ago it was down an inch. i did nothing,still no hint.
took a 1000 mile trip and aok,zero problems, still 1 inch down. temp is as always just below 1/2 even idling in 90+ air
any ideas???
Old Jul 30, 2015 | 01:55 AM
choochmalooch's Avatar
Cool
I had the same problem. Wound up being a small crack on the top tank of the radiator. The coolant evaporated as it was leaking. Once down below the crack it doesn't leak very much at all.
Old Jul 30, 2015 | 01:54 PM
happythree's Avatar
THAT, would be "good"news, thanks.
i see nothing so far
Old Aug 2, 2015 | 09:22 AM
arcaro's Avatar
My 2008 H3 radiator cracked at the top too. Might be a common problem with these things.
Old Aug 2, 2015 | 12:28 PM
happythree's Avatar
i still find no clue, nothing visible. i think a leak would let the pressure drop and lead to overheating??
still down one inch after about 1100 miles.
later:::
i filled to just above the case split and ill watch it daily. idling i notice nothing,smell nothing.
Old Aug 5, 2015 | 02:50 PM
Gomer's Avatar
Its wierd my coolant did that once too but only once. No smell, no hissing, no noticeable vapor, nothing in oil when I changed it. No clue what happened. Filled it up again and two years later might be down a bit but that has to be normal evap. No clue whatever happened. Maybe had a leak that got sealed somehow? No clue.
H2Miami
Jul 27, 2015 07:59 PM
SSPLUM
May 27, 2014 06:08 PM
nyff395
Mar 13, 2010 08:18 AM
sbsisco
Jun 23, 2008 02:17 AM
haiminger
Nov 26, 2007 08:07 PM
