Loose Roof Racks???
Old Oct 17, 2007 | 04:12 PM
Heysdad's Avatar
Default Loose Roof Racks???
Hey guys,
If you grab your racks and tug forward or aft, do yours slide at all? Mine do and I have tried everything I can think of to get them to stop moving. The only thing that I've found to work is to bang the front part of the black plastic backwards with my fist. that seems to jam them in place. If I don't the rattling drives me crazy.Am I missing something here????[sm=dontgetit.gif]
Thanks.....
Old Oct 17, 2007 | 04:56 PM
parts guy's Avatar
Default RE: Loose Roof Racks???
[ol]
I had to delete this post............I felt stupid,sorry folks[/ol]
[ol][/ol]
Old Oct 17, 2007 | 05:13 PM
Heysdad's Avatar
Thank you for the help, however I don't have lock *****. Mine have a locking arm that swings into lock and unlock, and have to be installed from the front by removing a plastic cover that allows access to the rails.
Are those instructions for H3? It looks like H2 racks????
At any rate...Thank you for posting that for me.
Old Oct 17, 2007 | 05:37 PM
bonzaiii's Avatar
Definatly something wrong there, mine do not rattle or slide around at all, But I was a little suprised they do not sit more flush.
Old Oct 17, 2007 | 05:40 PM
parts guy's Avatar
It's either late or I've been starring at my Avatar to much.
I thought I was in the H2 forum,sorry
When you pull the handle a screw type latch turns with the help of a
low tension spring to lock into place with the side rails. If they are not
locking down they maybe kuput.
Also look for rubber locking tabs the fit into the rail they will stop any movement
when put in front and back of the rail,I may have some laying around if you need them.
note this is not a real fix if you rails are broken,it will work but I'm not sure how much weight
they will hold back.
Old Oct 17, 2007 | 11:05 PM
radioactivesob's Avatar
I just installed mine. They are Aries ones and yes. They slide in between the stops. I don't know how to stop it, but I am open to suggestions.
Old Oct 18, 2007 | 09:55 AM
Heysdad's Avatar
ORIGINAL: parts guy
Sorry Guys..When I say slide, it's not a whole lot...It's not like they are going full travel of the rails. It's maybe 2-3 inchesthen they jam up again. They lock down into place ok with the arm pushed into lock,then if I tug on them.....They'll move.
They're brand new. Maybe 3 weeks old. They are the second pair I've had. I returned the first ones because I thought something was wrong with them. They were doing the same thing.
As long as I bang them into place, it's all good until I pull on them again.
I guess the moral here is "DON'T PULL ON THEM" ....LOL
Old Oct 18, 2007 | 10:54 AM
Hummer Guy's Avatar
What's happening is they're not locking into the right place, but rather between those places causing them to slide -- try moving them a long the rail and slowly trying to depress the lever. Don't worry - you'll find that sweet spot that locks them solid - patience is key.
Old Oct 18, 2007 | 11:34 AM
Trey124's Avatar
ORIGINAL: Hummer Guy
That's right, they don't sit flush with the roof but you have to find the right spot. Once you do they won't move.
Old Oct 18, 2007 | 12:10 PM
Heysdad's Avatar
OK..Thank you guys...I'll work on it.
