A little tail light wiring HELP! Please :)
Old Mar 16, 2013 | 09:25 PM
Thumper's Avatar
Default A little tail light wiring HELP! Please :)
Hello, thanks to the search threads I feel pretty good about installing rear bumper tail lights on my 03 H2. However, I could not find where there was any discussion (direction) on how to wire up the new lights. I did see where member "SafariHummerH2" provided a nice list of wire color to function list. And I plan to use his suggestion to tap into the trailer hitch harness.
But here is my issue. The connector I purchased has 3 wires a "Ground" (Black wire), a "Minor" (black with purple stripe), and a "Major" which is a green wire. If the ground is ground then does it matter which of the other 2 wires I hook up to the brake light or to the signal light on the connector so long as it operates as intended? Or is the connector sensitive to the which wire is connected to it. Since the bulb is to 2 filament blub, does it matter which one acts as the brake light and which acts as the signal?
Finally, when the light switch is turned on (for night driving) will the bumper light also turn on if it is connected to the brake light wire?
Obviously my lack of knowledge on wiring issues shows and I would really appreciate your help, just trying to avoid kicking the neighbors dog since I dont have one and blowing fuses left and right
By the way, in order to make the modification, I discovered that you also have to buy a bracket to hold the actual light unit in place from the inside of the bumper corner.
Thanks in advance!
Old Mar 17, 2013 | 06:32 PM
Thumper's Avatar
Com'on people nearly 100 views and no suggestions!
Old Mar 17, 2013 | 08:24 PM
calif phil's Avatar
Are the bulbs in those lights a double filament. If so then it will make a difference as one will power the brighter filament for the brake light/turn signal and the other will be dim for the running lights.
Old Mar 18, 2013 | 12:03 AM
Thumper's Avatar
yes it is ... ok so the "Major" marked wire coming out of the connector I will use for the brake/turn light and the "Minor" wire for the running lights. Thanks a lot
BlockandTackle
Feb 20, 2014 06:56 PM
Rideacanyon
Oct 16, 2009 07:21 PM
IYF_H3
Aug 17, 2008 06:31 PM
millheim
Jun 12, 2007 02:45 AM
wordstew
May 13, 2006 11:35 AM
