A little help please!
Old Feb 11, 2015 | 05:48 PM
citiboy's Avatar
Default A little help please!
2009 H3 Base 3.7L, can somebody check the underhood fusebox for FUSE 32 RVC VSENSE+ 10A. I just want to know if the fuse is installed, mine is missing. I don't have any weird problems on the 3 or any codes from my Tech 2. Just found out when i'm installing the windshield washer heater. Thanks!
Circuit/System Description
The generator battery control module (GBCM) monitors the battery voltage for precision electrical power management. The GBCM monitors both the RVC PWR B+ circuit and the RVC VSENSE B+ circuit to precisely determine system voltage. If the RVC VSENSE B+ circuit is 1.5 volts less than the RVC PWR B+ circuit for 7 seconds, then DTC B1390 will set.
Old Feb 13, 2015 | 09:22 PM
4Scargo's Avatar
I'm afraid I can't help, but does everything electrical work? Or, look in the owner's manual at the fuses. If I didn't have a manual, I'd stick in a fuse to see what I got, but that's me.
Good luck
Old Feb 14, 2015 | 10:23 AM
rsc's Avatar
rsc
I thought I had replied to this already...my truck has the fuse installed. I don't know what it does though.
Old Feb 14, 2015 | 11:09 AM
citiboy's Avatar
yes, you did sir on the other forum and thank you for the info. I included the circuit/ system descriptions for what it does. I installed the 10a fuse and monitor the charging system with the Tech 2, no change though with or without that fuse.
Old Feb 14, 2015 | 08:29 PM
rsc's Avatar
rsc
Thats what has me confused. I would expect to see a change somewhere.
BlockandTackle
Feb 20, 2014 06:56 PM
aliciajeanschmidt@gmail.com
Aug 27, 2013 03:42 PM
Thumper
Mar 18, 2013 12:03 AM
Rideacanyon
Oct 16, 2009 07:21 PM
wordstew
May 13, 2006 11:35 AM
