Liquid Force Omega Wakeboard and Alpha Bindings
Old May 9, 2008 | 02:37 AM
Pewterbird's Avatar
Default Liquid Force Omega Wakeboard and Alpha Bindings
http://cgi.ebay.com/ws/eBayISAPI.dll...:IT&ih=019
Description
Liquid Force Omega 139 Wakeboard and Alpha Bindings Package
Description of Liquid Force Omega Wakeboard
Ben Greenwood’s style fits the incredibly smooth characteristics of this wakeboard perfectly. A more humble version of the Substance, Ben helped design the Liquid Force Omega Wakeboard for the rider looking for an advanced shape to help them progress. With a snow style feel, it incorporates canted molded fins that generate hold for solid tracking on your heelside and toeside. Ben also wanted variable edges for smooth forgiving spins that help define his style. The pop rocker increases lift for consistently big wake to wake jumps with smooth landings. The Omega is great for a rider looking for a smooth transition into the pro status.
Experience the perfect foundation for progression with the Liquid Force Omega Wakeboard.
Features:
Scalloped Diamond Tail - Extended hold up the wake increases the pop off the tail
Pop Rock - manageable 3-stage rocker that is fast and consistent off the wake.
Variable Edges There’s no catch - Soft in the middle - Forgiving when neutral, spins faster off the wake, land still spinning - Sharpens as it nears the tail - Locks and holds edge into the water when weight is transferred into the edging position.
Molded Canted Fins - Easier to get board on edge. Helps the board initiate turns and hold better switch stance, toeside, and heelside. Solid and consistent tracking from any side. Long and shallow for quick release when needed. No drag.
Long Base Center Fins
Sculpted Top Deck w/ Flex Enhancers - Light weight, stiffens snap and response.
Description of Alpha Bindings - Size L (9-10.5)
The Alpha continues to dominate the class of support and mobility. Integrated stretch zones mold to your foot and hold with confidence. This year we added the FAST system plate for response and unlimited stance options. There is no comparison to the binding that started the sewn overlay craze. The Alpha has the support and performance a pro level rider needs with the value and flex pattern you’re looking for.
Sewn Overlay Technology/Integrated Stretch Zone - Maximum support and comfort with stretch and release points where needed.
Molded EVA/Lycra Heel Piece - Molded heel kidneys lock your heel into riding position providing support, response and superior hold. Lycra provides a soft comfortable heel that is easy on your foot.
Molded EVA/Lycra Toe - Eliminates pinch points to fit your foot the way a boot should. Lycra provides a soft comfortable toe that is easy on your foot.
Padded Inner Cuff - Padded for comfort and leg friendly support.
C3 EVA Foot bed - Canted for proper alignment. Cupped for maximum hold. Contoured for premium arch support. Comfortable shock and pain free riding all day.
Dual Lace Zones - Fine tune your desired feel, support and hold.
F.A.S.T. System- Adjust every 2 degrees. Easy to use. Locks down for 360 degrees of hold down. Reacts with your movements transferring the energy directly to the board.
Old May 11, 2008 | 02:34 PM
Pewterbird's Avatar
Default RE: Liquid Force Omega Wakeboard and Alpha Bindings
Sold
Old May 11, 2008 | 06:53 PM
Glad it sold so quickly. What H3 stuff you going to get with the $$$$?
H32006
Nov 3, 2014 06:21 PM
07HummerH3
Apr 4, 2007 11:57 PM
chsnprodigy
Mar 21, 2007 12:35 PM
slate06H
Nov 6, 2006 10:25 PM
dilo2001gt
54
Oct 2, 2006 04:55 PM
