Leveling H3
Old Sep 29, 2006 | 12:07 PM
jlock71's Avatar
Default Leveling H3
After looking at my front suspension I am thinking it may be possible to just reindex the tosion bars in the lower control arm and gain the same 2 inches as the kit gives you. I'm aware I will have to reset my camber and toe but it has to be better than it is now. Mine is sitting on the bump rubbers. (lux non offroad suspension) anyone ever try it . As I do agree cranking up on the bolts is not the correct eay to do it .
Old Sep 29, 2006 | 12:56 PM
HummerGuy's Avatar
Default RE: Leveling H3
You can turn the adjustment nuts clockwise to raise the H3. I personally turned them each 1 3/4 turns for each side as did one of my friends. He actually went 2 full turns for each. After you turn them 1 turn, you start to notice a little more bounce to the front wheels when going over bumps, but it's very small. I didn't readjust the camber or anything and i've driving over 1000 miles like that. I haven't seen any different wear then normal, but that's just me.
Old Sep 29, 2006 | 01:14 PM
shortbus's Avatar
reindexing the torsion bar in the lower control arm won't do anything, since you'll have to take off the adjuster keys to get the torsion bar out, then you're right back where you started. truning the stock keys has helped most people level out their vehicles, and it won't be a warranty issue if something were to break in your suspension. the offset adjuster keys are the only way to get additional lift with everything else remaining stock.
as for alignment after the fact, it's necessary. if you push up on the control arm, you're bringing the bottom of the tire in closer to the vehicle, and you'll wear out the outer edge faster than normal. or, you could just drive over granite boulders and rip off lugs from the tire surface, then you won't notice as much. [sm=boosign.gif]
Old Sep 29, 2006 | 01:15 PM
CerberusSVT's Avatar
I think I'm going to crank my torsion bars this weekend, I'm sick of having my truck look like its ready to plow the front end into the ground! [:@]
How many turns should I go? 2, 2.5....?
Also, I know I'm jumping all over this thread (sorry!) but how did you raise up the front end so that you can crank the t-bars? should I just have one front wheel up on a ramp or something, or is there a place tha I can use the factory jack to lift it so there is no strain on the suspension?
Old Sep 29, 2006 | 01:18 PM
shortbus's Avatar
to do it correctly, just put a jack under any part of the frame to lift it, taking pressure off the front wheel. i'd start slow, with 1 1/2 turns, see how it looks, then go more if necessary.
Old Sep 29, 2006 | 01:19 PM
HummerGuy's Avatar
I guess I misunderstood the question. Thanks for clarifying it. DOH!
Old Sep 29, 2006 | 01:22 PM
HummerGuy's Avatar
You don't need to raise it at all. A 10 year old can turn those things. All you need is a socket wrench with a 1 1/16 socket. They turn very easily. I would not go beyong 2 complete turns. I turned it 1/2 way at a time, went for a drive to get it readjusted, then came back and did another half turn. Mine are 1 3/4 on each side right now. That almost did the trick. I wouldn't push it if I were you. It's not the right way to do it anyway, but it works, and you'll be happy with how it looks afterwords.
Old Sep 29, 2006 | 01:25 PM
shortbus's Avatar
i'd recommend that you get an alignment though. anytime you change the way the suspension handles the front end it's a good idea. cranking the adjustment keys pushes up on the control arm, and now that i think about it, that pushes the bottom of you tire out, not in, so you'll get uneven wear on the inside, not outside. either way, and alignment is a good investment, cheaper than tires.
Old Sep 29, 2006 | 01:31 PM
ORIGINAL: shortbus
if I take it off some sweet jumps, does that count? j/k, I'll get an alignment after I give the suspension to settle
Thanks guys! I'll take some before after pictures
Old Sep 29, 2006 | 01:38 PM
jlock71's Avatar
do any of you have the offraod suspension package ? If so look at the t bar and see if it has this part number on it .
T bar LF 0393346 ZJ
