Leveling H3
Old Oct 1, 2006 | 01:36 PM
  #21
Ghostrider's Avatar
Default RE: Leveling H3
could somebody post a picture of the t-bar?
Old Oct 1, 2006 | 04:56 PM
  #22
Dennis's Avatar
Torsion bar Looking forward (Driver's side)
Torsion bar engaged into control arm of front suspension
Adjustment bolt (I think a 25 MM bolt..CW to raise front end)
Top of adjusting bolt in torsion key..
Are these kinda like what you meant by pictures of the T-bar?
Old Oct 1, 2006 | 05:45 PM
  #23
CerberusSVT's Avatar
its easy to find, lay on your back, its under the back seat area of your truck, pointing downward from the frame (facing the ground). Its a big hex bolt that looks exactly like the one that the wrench is on in dennis' pictures. its a 1 1/16th inch socket that fits it if I recall correct.
Why is one side slightly higher than the other??? I even over adjusted my drivers side to try to raise it up a bit more to equal it out...
Old Oct 1, 2006 | 11:29 PM
  #24
Ghostrider's Avatar
ORIGINAL: Dennis
Perfect!! Thanks!!!!!
Old Oct 2, 2006 | 10:17 AM
  #25
jlock71's Avatar
I did mine 2 1/2 turns left and right. much better looking and the ride is also better , I was getting alot of bump steer befor I raised it ,Prob because they sit on the bump stops. Thanks Guy's
Old Oct 2, 2006 | 10:24 AM
  #26
does this look like I turned my t-bars enough/right?
Old Oct 2, 2006 | 06:03 PM
  #27
ChevyHighPerformance's Avatar
ORIGINAL: CerberusSVT
ORIGINAL: shortbus
i'd recommend that you get an alignment though. anytime you change the way the suspension handles the front end it's a good idea. cranking the adjustment keys pushes up on the control arm, and now that i think about it, that pushes the bottom of you tire out, not in, so you'll get uneven wear on the inside, not outside. either way, and alignment is a good investment, cheaper than tires.
if I take it off some sweet jumps, does that count? j/k, I'll get an alignment after I give the suspension to settle
Thanks guys! I'll take some before after pictures
It's not a SledgeHammer! Gosh!
Old Oct 2, 2006 | 06:41 PM
  #28
shortbus's Avatar
ORIGINAL: blackstangs281
Hey Shortbus, does the same go for the H2?
all my comments are based on the H2, it's all i have experience with. for the H3, i'm basically talking out my ***, since i've never adjusted one. still, the mechanics and physics are basically the same, so i would say there's little if any difference between the 2 aside from size (mine's bigger !). an alignment is always a good bet anytime you mess with the front suspension, but it's up to each individual as to the value of an alignment vs. a chance to get new shoes. [sm=burnout.gif]
Old Oct 2, 2006 | 07:07 PM
  #29
jlock71's Avatar
The H2 also is a coil front end right
Old Oct 2, 2006 | 07:09 PM
  #30
jlock71's Avatar
never mind just checked it out ,,would have thought they had coils
