Leveled h2....can I run a 37 1250 20 on 20x12 rims?
Old Nov 21, 2013 | 11:53 AM
Hemiman74's Avatar
Default Leveled h2....can I run a 37 1250 20 on 20x12 rims?
Wanting to run 371250 nitto trail grapplers on 20x12
Fuel octanes with only my truck leveled is this possible? Thanks
Old Nov 23, 2013 | 12:05 PM
Duane87's Avatar
I just put 35's on my new 20" wheels and I wish I would have went with 37's...
Old Nov 24, 2013 | 06:22 PM
KruBruder's Avatar
My wife has Fuel Hostages on hers leveled with Toyo MT 35's....Big mistake. Should have gone with the 37's. Yes 37's will fit under a leveled H2. You may rub a little bit backing out of a tight turn. But ultimately, chicks will dig it, which is great for your ego...especially if your married...and your wife notices how much you are now getting noticed. Sorry, sometimes I just like pissing off my wife.
Old Nov 25, 2013 | 05:42 PM
Caraddict's Avatar
I had 37" tires.. I just cranked up torsion bars...they rubbed at full turns but worth it cause it looked sweet...till I got a lift then I needed 40" tires as the 37" tires looked tiny....
Old Nov 25, 2013 | 08:36 PM
Autumn Walker's Avatar
I'm running 38's on my truck with just front end leveled. Rub a bit at full lock or stuff when offroad, but it's not bad.
Old Nov 26, 2013 | 03:57 AM
Hemiman74's Avatar
Default Thanks
Thanks guys. I ordered fuel octane 20x12 with 35 12 50 20 nitto trail grapplers. Hope it looks good. I pull a 24 ft boat so I played it safe.
Old Nov 27, 2013 | 06:07 PM
H2CANEPADESIGN's Avatar
Sorry but the answer is no. the Nitto 37x1250r20 has an approved rim width of 8.5 to 11.0 Running a 20x12 is a bit of a stretch. the problem lies in the fact that when you look at the tire from the front it is gonna appear stretched over too much rim. it creates a gap in the center of the tire from the road and can increase the possiblilty of hydroplaning, have an issue with always wearing on both edges and will make it ride rougher than it should. They will fit on the wheel but it is not correct. If its just all about looks then no worries.
Specs/Size
SIZE37X12.50R20/10 UTQGLNA 126Q P/N 205-800MIN RIM WIDTH 8.50 MAX RIM WIDTH11.00 OUTER DIAMETER36.77Single Max Load lbs3750@ RPM 564TREAD DEPTH21.00
EvanMEllison
Mar 14, 2014 09:48 AM
Roy79
Apr 23, 2013 10:53 AM
bigwheelsH123
Feb 18, 2012 09:49 PM
bigdog100
Jul 5, 2011 07:54 PM
23window
Jan 15, 2009 12:58 PM
