can i run 37" procomp xterrains with no lift?
Old Dec 21, 2008 | 04:28 AM
23window's Avatar
Default can i run 37" procomp xterrains with no lift?
Hello all.Ihave a stock height 03 h2 on 17" eagle 102 rims. Can i run 37-13.50-17 inch procomp xterrains with no lift or problems?thanks!!!
Old Dec 21, 2008 | 09:49 PM
Quijy's Avatar
Default RE: can i run 37" procomp xterrains with no lift?
yes, but you will have to trim the front wheel wells just a bit. I run 36" on my 05 with ZERO problems.
Old Dec 23, 2008 | 11:05 PM
L2C's Avatar
L2C
I have Toyo 37" and it rubs the inner tire if you turn left or right all the way and the wheel wells rub when u go up a driveway real fast. The rear needs to be shaved on the inner part where the frame is. It doesn't touch but it might if you go up a driveway fast. I shaved it just in case
Old Jan 8, 2009 | 12:57 AM
blackterror's Avatar
I have 35's on 17's on mine with no problem...35 or 36 should be fine without any mods
Old Jan 14, 2009 | 03:21 AM
madmike's Avatar
Banned
I got 37's mud terrain on mine with no problems. I dont think I have a lift.
Old Jan 15, 2009 | 12:58 PM
HumminNBoatin's Avatar
Go with a 12.5 inch wide tire. Stay away from the 13.5"inch tires especially if you have air ride. I have 37x12.5x18 BGF KM's on mine and the only rubbing I get is on the front sway bar. No trimming was required and no lifting was required.
If you get the 13.5 inch tires you are going to have to modify your ride height sensors in the rear because the first time you go to flex that rear suspension your going to rip that sensor right off the frame.
hummer07owner
Oct 16, 2010 03:08 AM
PNW-H3
Jan 13, 2010 01:28 PM
JeepeaterH3
Jun 25, 2008 04:34 AM
sanddragger28
Feb 18, 2008 12:29 PM
indyh2
Jun 8, 2007 05:32 PM
