LED turn signals flashing fast
Old Jul 22, 2010 | 06:08 AM
jpower9's Avatar
Default LED turn signals flashing fast
I just added LED lighting to the rear tail lights and front turn signals of my H2. The rear lights came with resistors so after I put them in the lights flashed at a regular rate but the front lights didn't come with resistors and now all of my turn signals flash fast. Does anyone know what size resistor will fix the problem? Also, which wire do I hook them up to?
Old Jul 22, 2010 | 11:57 AM
Pauldy's Avatar
If you have to get a cheap pot tune it to what your looking for then use an ohm meter to figure out resistance. No ohm meter and a volt meter you can use a known resistance to create a voltage divider to come up with the unknown resistance. Course it is probably the same as the rear and you could just measure it worse case.
Old Sep 3, 2010 | 08:46 PM
jpower9's Avatar
Default Additional help?
Ok, I don't understand a word you just said. Can you walk me through it? Does somebody know the size of resistors I need?
DrCarver
Mar 13, 2008 01:18 AM
tarheel_34
Jan 29, 2008 08:51 AM
Heysdad
Nov 5, 2007 08:25 AM
bobh002
Sep 6, 2007 06:59 PM
hsbertiii
Feb 13, 2007 10:14 PM
