Clear Turn Signals....
Old Jan 26, 2008 | 10:54 PM
tarheel_34's Avatar
Default Clear Turn Signals....
How hard are the clear turn signals that they sell on eBay to install? I know that I will have to take the grille off, just wonderin how hard it is to get off... I put the lower grille with the fog lights on and that was cake, how does this compare?
Old Jan 27, 2008 | 05:32 AM
Steve #1's Avatar
Default RE: Clear Turn Signals....
ORIGINAL: tarheel_34
The grill is held in with 6 screws (apparently 4 on the early 06s) and a couple friction clips. Remove the screws and pull the corners forwardby the signals.
Old Jan 27, 2008 | 07:13 AM
D VADER's Avatar
The front grill has to come off as well as the inner fender panels. About a 90 minute install.
Old Jan 27, 2008 | 08:53 AM
hsbertiii's Avatar
I have an 07 and only removed the front grill and was able to change the side markers and turn signals. I did not have to remove the inner fenders on mine.
Old Jan 27, 2008 | 10:30 AM
tarheel_34's Avatar
Thanks Vader, those pics help.... Shouldn't be too hard to do...
Old Jan 27, 2008 | 11:12 AM
alrock's Avatar
It won't be bad at all. Of those 90 minutes, 70 are on the first side figuring out the clips for the wheel well liners (easy, pull down the insert in the middle of the clip, then pull the whole clip out) and 20 minutes on the second side. Vader pulled off his wheels; I left mine on.
Old Jan 27, 2008 | 01:29 PM
D VADER's Avatar
I've got a big head and **** so I needed the roomand I pulled my wheels. Damn those are heavy!! If I had it to do over I'd switch the bulbs out too. As you can see in my pic they have a yellow cast.
Old Jan 27, 2008 | 06:47 PM
They look cool though. Nice work D Vader.
Old Jan 27, 2008 | 06:51 PM
rhill20's Avatar
Looks good, are they LED? Been thinking about switching to Smoked LED's.
THINK PINK WHEN YOU VOTE FOR ROTMTIME IS RUNNING OUT![sm=smiley20.gif]
https://www.hummerforums.com/m_121425/mpage_7/tm.htm
Old Jan 27, 2008 | 09:41 PM
alrock's Avatar
Oh, yeah, I forgot, as Vader said you probably want to change the bulbs to the stealth bulbs or whatever they are called. The don't show as yellow until they are lit; the rest of the time there might be a very slight bluish reflection in the lens.
