King Kong put on my...
Old Apr 26, 2006 | 10:30 PM
aetherH3's Avatar
Default King Kong put on my...
nerf bars. I cannot get any of the bolts except the front p/s loose. Its rediculous, i want them off.[:@]
Old Apr 27, 2006 | 09:15 AM
GregDiesel's Avatar
Default RE: King Kong put on my...
I bent one of my brackets going off road and I'm going to attempt to remove to straighten them.
Old Apr 27, 2006 | 09:34 AM
dilo2001gt's Avatar
ORIGINAL: aetherH3
They put them on at the dealer and they you a inpack wrench so they will be tight it be easier if you had that air tool or use a small pipe over you handel to you socket or the last thing to do go to a welding shop let them cut them off.
Old Apr 27, 2006 | 12:40 PM
Dennis's Avatar
You also could try soaking the nuts/bolts in penetrating oil (Brake fluid works good too) for a few hours
Old Apr 27, 2006 | 03:49 PM
Linus Gump's Avatar
Keep in mind that brake fluid will remove paint if you go that route.
Old Apr 27, 2006 | 04:09 PM
dilo2001gt's Avatar
Or just soak them with liquid wrench
but they should not be rusted on it fairly new.
Dennis will go help you , you just need a little muscle
Old Apr 27, 2006 | 04:10 PM
dilo2001gt's Avatar
oh sorry your not h3 gal
Old Apr 27, 2006 | 05:01 PM
Dennis's Avatar
ORIGINAL: dilo2001gt
And don't you forget it little mister!
Old Apr 28, 2006 | 03:39 PM
aetherH3's Avatar
i don't really think that liquid wrench will help since the truck is only 3 weeks old. One of the main problems is in the back where they are bolted to the frame, its extremely hard to get any sort of leverage in there.
Old Apr 28, 2006 | 08:52 PM
Linus Gump's Avatar
I put the rock rails on mine in my garage. I know what you mean about no leverage. I just used a combination wrench and a socket, and depending on the bolt, only got one click on the ratchet, or one corner with the box end of the wrench.
