Keyless Entry Remote
Old Sep 5, 2007 | 02:54 PM
H2Germany's Avatar
Default Keyless Entry Remote
Hi!
I am new to this forum.I own a 2003 H2. Is anybody here to can tell me how i can programm the new original H2 remote control?
Thanks from germany,and sorry for my bad english
Old Sep 5, 2007 | 03:41 PM
Default RE: Keyless Entry Remote
Hello H2Germany. WELCOME. Don't worry about the english, you are doing fine!! I do not know how to program the remote, so I would go to a dealer. I think any GM dealer could do it for you?????
Old Sep 5, 2007 | 04:48 PM
CRXMA22's Avatar
for a garage door? or to get into your car?
oOps... he did say keyless nevermind...
Old Sep 5, 2007 | 04:55 PM
shortbus's Avatar
i had a buick dealer program my new spare, so if you've got a GM dealer nearby you should be in luck.
Old Sep 7, 2007 | 06:03 AM
H2Germany's Avatar
Hi,thanks for response!
The german GM-Dealer charges me €50 for the programming of one remote. Thats about 68 Dollar.I have seen in a Ebay auction this:
"You will receive easy to follow programming instrucitons that you can do yourself without the expense and hassle of going to the dealer. The simple instructions require no tools or specialized knowledge."
http://cgi.ebay.com/ebaymotors/02-06...QQcmdZViewItem
This is what I need,to save $136. ;-)
Old Sep 7, 2007 | 10:43 PM
Hummer Guy's Avatar
It comes to me when I'm in the truck, but try this:
With two remotes in hand, hold down lock button on the driver's door and turn ignition to on, then off, then on, then off, then on, then off pretty quickly -- the horn will honk. Hold down BOTH buttons onONE remote (it will take a few moments). Wait until the locks cycle in the truck, then immediately do the same with the other remote. The locks will cycle again. Then turn the key to the ON position, and it will honk again and confirm the process.
It's pretty close to that -- I normally get it on my second try when I'm in the truck.
Old Sep 8, 2007 | 02:44 AM
I found this online:
Method 1 - No Tools Required
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
9. Operate the transmitter functions in order to verify correct system operation.
Old Sep 8, 2007 | 08:21 AM
Muddydawg75's Avatar
yeah... bob is onto it.... I think it is in the owners manual also....
Old Sep 8, 2007 | 11:09 AM
Hummer Guy's Avatar
Yea, that sounds right..
Mini_Fan
16
Jan 19, 2014 12:12 PM
varun
Jun 8, 2012 05:06 PM
SMLNBAD
Jul 7, 2009 06:08 PM
rmoore
Dec 22, 2008 09:36 AM
93Miata
Oct 8, 2005 11:50 PM
