key stuck in ignition
Anyone have this happen? I read the post on what to do to get the key out, that was helpful, but having to use a screwdriver to get the key out of the ignition every time is annoying. Also it will shift through the gears without the brake pressed. No broken wires under dash, no battery drain, just the problems mentioned above. Anyone had this problem or have any ideas?
Didn't work. I can hear and feel it locking the key in the ignition as soon as I turn it past the off position. Doesn't explain it shifting without the brake applied either. I am thinking brake switch, ignition switch, or something else. Would like to target the problem instead of replacing everything related to it.
nncanfarelli
Aug 4, 2019 09:27 PM
hummerhonduras
42
Sep 19, 2012 11:49 AM
ezspirit
Jun 29, 2009 07:13 AM
doyleh3
Apr 2, 2008 10:01 PM
