K&N Air Intake w/Heat Shield - Install Question
Old Oct 7, 2010 | 09:22 PM
deebocubs's Avatar
Default K&N Air Intake w/Heat Shield - Install Question
Just installed K&N 63 Series Aircharger... I noticed some gaps where the Air filter connects through the heat shield. I also noticed one towards the front of the heat shield and the inside of the engine. Is this normal. I was under the impression that this was going have a tight seal all around the heat shield. Is this normal? Do these gaps take away from the performance? Thanks!
[IMG]file:///C:/Users/owner/AppData/Local/Temp/moz-screenshot.png[/IMG]
Attached Thumbnails K&N Air Intake w/Heat Shield - Install Question-hummer.jpg
Old Oct 8, 2010 | 11:22 AM
Yep, your observations are completely normal, that is why I refer to the open systems as a "warm air intake".
Closed systems rule.
Old Oct 8, 2010 | 11:53 AM
johns_d's Avatar
i have gaps around mine and was wondering the same thing when i first installed it. it hasn't seemed to make a negative intact. and im assuming that the gap is to allow for engine movement since the airbox is mounted to the body and the intake to the engine.
Nurse0115
Jul 12, 2013 12:59 PM
nlhummer
May 16, 2013 02:04 PM
VTCanyon06
Aug 5, 2011 07:55 PM
vger105
Mar 11, 2009 01:13 PM
jens
Feb 10, 2009 11:30 AM
