Just got an H3X
Old Nov 27, 2017 | 03:15 AM
ccaligator's Avatar
Default Just got an H3X
Hello everyone,
Just got an H3X and I have to replace the valve cover gasket. Does anyone know the bolt pattern and torque specs? I’ve researched and can’t seem to find anything.
Old Nov 27, 2017 | 06:52 AM
Welcome to
please state the year and engine you have.
Old Nov 27, 2017 | 10:40 AM
ccaligator's Avatar
inline 5
Old Nov 28, 2017 | 12:47 AM
ccaligator's Avatar
Originally Posted by TAINTER
Welcome to
2008 In-line 5
Old Nov 28, 2017 | 01:32 AM
On the I5 it is considered a cam shaft cover. Maybe that's why you were unable to find the specs.
The specs should be the same for the 3.5L and the 3.7L.
-Install the camshaft cover bolts and tighten to 89 inch lbs. (10 Nm).
-Check the gap on all of the spark plugs. The gap should be 0.042 inches (1.08 mm). Tighten all of the spark plugs to 13 ft. lbs. (18 Nm).
-Install the ignition coils into the camshaft cover.
-Install the ignition coil bolts and tighten to 89 inch lbs. (10 Nm).
Hope this helps
Old Nov 28, 2017 | 01:38 AM
ccaligator's Avatar
Hope this helps
thanks! Is there a certain pattern I need to follow when putting the bolts back in?
Old Nov 28, 2017 | 07:26 AM
No pattern is mentioned. I like to snug all the bolts down then torque from the inside out.
Remember that's inch pounds. Does not take much to ruin or smush a gasket.
Romanzz
Apr 12, 2012 06:10 PM
bsc819
May 20, 2011 02:59 PM
dilo2001gt
17
Jan 8, 2008 10:32 PM
sdominiq
Oct 27, 2007 04:50 AM
sarge_taz_rock
Oct 9, 2007 07:46 AM
