I've been thinking
Old Aug 16, 2007 | 11:58 PM
importkiller's Avatar
Default I've been thinking
Maybe F5stop can give us some info if he reads this.
The alpha h3 has higher rated t-bars (for the added weight of the v8) so I assume they can be swapped into an 06 or 07 h3 with the i5 for a slightly stiffer ride...but it would also be much much better when your running a front push bar and winch combo...it will handle the weight with no dip. Alpha also has a cast iron front diff, the i5's have a aluminum housing. I was seriously considering keeping my 06 and either supercharging it or adding a turbo kit...but there is no way the stock diffs would handle the added ponies, hell they are getting blown up with the stock motors. I'm wondering if the alpha diffs would be interchangable? That would make adding go fast parts possible. Has anyone heard anything about these swaps? I don't see why they wouldn't work.
Old Aug 17, 2007 | 05:11 AM
D VADER's Avatar
Default RE: I've been thinking
Interesting thought. I imagine it would also lift the front a bit?
Old Aug 17, 2007 | 07:15 AM
HummerGuy's Avatar
Differential:
My friend that works at the serv. department told me they would be interchangeable, but this was before it was released. He got the info from someone at Hummer I believe. We had an entire conversation about it. I don't know if the final version is though, but originally it was supposed to be interchangeable.
Old Aug 17, 2007 | 08:24 AM
jdrew's Avatar
the iron diffs will swap into our beaters...
Old Aug 17, 2007 | 08:37 AM
D VADER's Avatar
ORIGINAL: jdrew
Off topic but I have a H3 and the wife has a Hemi Magnum! I use hers to get my speed fix!
Old Aug 17, 2007 | 08:45 AM
Wasn't it the gears that fractured up front, not the AL carrier? I also thought I read they changed geometry in the front suspension to fit the V8, so I don't know about swapping T bars??
Old Aug 17, 2007 | 11:24 AM
D VADER's Avatar
By no means a comparison but went they dropped the 6 liter V8 in the CTS the geometry was beefed up but the positioning remained the same. I used the sway bars, struts and coils from the CTS-Von my base CTS. GM likes to keep things simple and cheap. Maybe it applies here as well?
Old Aug 17, 2007 | 11:26 AM
JDJoe's Avatar
Yeah, not sure about the T-bars. But GM's own press release for the Alpha said that the front diff would be swappable into all other H3's.
Old Aug 17, 2007 | 12:27 PM
doc, alot of h3's front diffs were exploding...literally..the cases were snapping. I think hummer mike had a broken front diff case.
Old Aug 17, 2007 | 08:43 PM
H3X442's Avatar
The diff may bolt in but the gear ratio is different in the alpha. The alpha has 4.10 ratio and the older ones are 4.56(swap gears?). Don't know about torsion bars but the uundercarriage looks the same. Steve
