Installing aftermarket Amp
Old Jul 2, 2011 | 10:00 AM
DJONES's Avatar
Question Installing aftermarket Amp
I've decided to add an aftermarket amp and sub to my H3 based on feedback from other posts on this forum.
I have a JL Audio high to low level converter than I can use to tie into my monsoon amp line level for RCA inputs to my aftermarket amp.
My big question is where is the best place to run the power wire from the battery through the firewall? I know the H3 is supposed to be submersible up to 3 feet I think so I don't want to compromise that.
Thanks in advance.
Old Jul 2, 2011 | 10:50 AM
talusfan's Avatar
The 3 has can ford water up to 24", It is not submersible. You can run it thru the boot on the drivers firewall or just get a grommet and drill a hole. If water gets up that far its coming in the doors anyway. Water makes for expensive repairs.
Old Jul 2, 2011 | 11:13 AM
drtom's Avatar
Banned
if u get the hole in the right place!?? dont hit anything important!
curious which amp and how it connects to the various h3 speakers?
Old Jul 3, 2011 | 10:37 AM
DJONES's Avatar
I guess submersible was a bad choice of words. I just knew that the H3 could tread water. Thanks for the info.
Old Jul 3, 2011 | 10:39 AM
DJONES's Avatar
I am adding an amp to power an aftermarket sub only. Planning to use the existing factory door speakers as is if it sounds okay. I am pleased with it so far.
samiparts
Aug 23, 2016 01:10 PM
lostsoul77
Sep 22, 2015 05:32 AM
6spd04cobra
Jan 26, 2011 12:41 PM
justin67
Dec 18, 2010 01:12 PM
tjrat25
Jul 7, 2009 09:17 AM
