Injectors clogged
Old Mar 14, 2012 | 08:30 AM
Cashville's Avatar
Looks nice, I'll look into it.
Thanks!
Old Mar 14, 2012 | 02:05 PM
sirbob's Avatar
Originally Posted by inputapmech
Bg 44k does work well and is worth a try but I would use 2 cans in 1 tank of gas. If that does not do it than professional fuel injector service involves hooking up a machine that runs your engine during the cleaning process since they will remove your fuel pump fuse and that works very well as I purchased the snap on machine off ebay about 5 years ago..... I know....
Yep, have the same Snap-On set up myself. I've always used the BG injector cleaner for that. Works really good. Depending on where the two fuel ines connect on the injector rail, you can just loop the supply fuel line back to the return line (assuming ofcourse it has a return, most newer vehicles don't have a return fuel line) as to avoid setting a fuel pump relay or power code in the PCM by removing the fuse. Just another way.....
Also my experience with doubling up on the BG44K in a larger fuel tank, or adding a single can to a half full fuel tank, is that the mixture is too strong and will break up (on higher mileage vehicles) carbon deposits in little chunks, instead of desolving or burning the deposits off. (same results of sucking cleaner through a vacuum hose in the manifold)
Depending on the type of Catalytic Converter you have, (cross comb especially) it will start to plug your cat. Thus resulting in loss of power, vacuum, which can affect shifting...etc.
From my experience it's better to lean out your cleaner to fuel mixture that you put in the tank, and do it through a couple of tank fulls, than to rush it and potentially set yourself up with concerns not expected.
Old Mar 14, 2012 | 07:55 PM
Cashville's Avatar
Today the code P0174 (System too Lean) came up again...
The seafoam is on the way to me, I doubt it will completely solve my problem though...
Old Mar 21, 2012 | 06:27 PM
Cashville's Avatar
I'd like to do the smoke test, to see if I have any leaks in the intakes or anything... I would like to know where the smoke should go in the engine, what should I unplug to plug the smoke machine?
Broken Halo
Aug 25, 2025 09:48 AM
racin
40
Jan 26, 2018 10:11 PM
SuperH1
Jun 18, 2011 02:28 PM
pbarron
Jan 18, 2009 01:15 AM
